Fallingwater
I see that several high-end lights that have come out lately use the piston system. I wonder: what's so good about it that makes it preferable to a switch?
Piston lights? Hmmmm . well being from near Detroit I would say they would be great during normal uses, but when it really counts they would stop working.
also, can someone confirm for me, is the Piston on the D10 easier to press then the Ex10? as in, less "action"? seems like that for me..
i have actually had water sneak its way in, a tiny bit, beyond the o-ring before.
Crenshaw
I'm trying to decide on one, the D20 looks damn nice.
One thing I'm not so sure about is for an emergency light. If you get dirt on the tube while changing batteries, and don't have your trusty tube of silicone lube with you, then what? I read the switch can get flaky if not lubed properly. Are you stuck with a flaky light, or can still resort to momentary use?
This system would probably work better if the mating surfaces were gold plated or similar. They aren't, it's stainless (or nickel plated steel) tube on brass. The brass presses against a gold finished board, but there is no way to get under there and clean/condition the surfaces. Really, the brass ring should be plated with gold for best operation, and removable for occasionaly cleaning.
are you sure about that? how could you check? if you checked by pulling out the piston theres a very good chance that its just the water off the other side of the o-ring being left behind, the piston design is very good in my opinion, and it doesnt seem to bother McG, who is in the water with a PD light more than anyone.
I'm pretty sure the tube is steel with nickel plating. Maybe the coating that is used on the CR2 Ion or Muyshondt lights (I want to say ChemKote, but that's probably wrong) would improve conductivity. I don't think that they can change to a brass tube, though, as it may compress/deform over time.
