archer6817j
Hi all,
I've been working towards more flexibility in the UI on my lights. I was hoping to offer a new driver that would allow up to 9 user selectable modes. However, I've run into a little hitch with that. See this thread if you can help me out with programming a PIC controller.
In the mean time, I hope to offer Blue-Label lights with a choice of programs on the same NANJG 105C driver that I've been using. The Ready-Made lights will still come with a basic H/M/L 3 mode setup. I know the 105C also has solder bridges that can allow you to access other modes, but there are two problems. One, they are way to large and too far apart to solder cleanly and easily...bad design. Two, right now the guy that is going to write the programs for me can only alter the default program. At this time, we don't know how to rewrite the base code to alter all of the on-board mode groups. PM or email if you can help with that.
So, the plan is to offer a selection of UI's that can be dropped onto the chip on an "as requested" basis. If you have suggestions for other mode groups please let me know. These are just the basic ones I've come up with.
* First some nomenclature:
*NOTES:
MODE GROUPS:
So, do you vote for any of these or do you have suggestions about the UI you most prefer?
- High: 100%
- Medium: 30%
- Low: 5%
- MoonLight: 1% (this will approximate .25 lux @ 1m, the ANSI definition of "moon light")
- FireFly: <1% (this is a low-low that is low enough you can look directly into the emitter without discomfort. I can't measure this low...but you get the idea)
- Strobe: self explanatory? Only needed by DJ's and people who carry guns for work (IMO)
- SOS: Errr, you can remember 3 long 3 short right? I don't plan to offer this as a mode since I can't "hide" it from the primary mode navigation
*NOTES:
- The memory delay will be altered to have a 1 second interval instead of the current 2 second interval. This should make the lights much more user friendly and significantly lower the number of unintended level changes.
- Alternately, the driver can be programmed with NO memory and can cycle modes in any order desired
- #4 (below) was actually developed by a police officer for "duty" use. It has no memory and activates on High every time. It has a MoonLight mode for things like reading ID's up close at night and a strobe to use on people you don't like very much.
- It is NOT possible to have the memory set during the OFF time, only the ON time
- Hidden modes accessed by twisting the head are not possible
- Multiple clicking is not possible (eg click 3 times for strobe)
MODE GROUPS:
- 4 mode H/M/L/Moon (default)
- 4 mode H/M/L/FireFly (full monty)
- 3 mode H/L/FireFly (cat burglar)
- 3 mode H/M/Moon (fridge burglar)
- 3 mode H/Moon/Strobe (on duty) >> no memory <<
- 2 mode H/L (old school)
