shootist16
- Joined
- Aug 23, 2001
- Messages
- 67
Been away from the forum for awhile. Any updates on the ARC LS?
<font size="2" face="Verdana, Arial">You may be surprised! I was.Originally posted by Charles Bradshaw:
It is not likely that it will be my most used LED light.
<font size="2" face="Verdana, Arial">----------------------------------------Originally posted by shootist16:
<font size="2" face="Verdana, Arial">Thanks for the answer Chris. I have an LS that appears to sometimes go into a "moon mode" even with fresh batteries. It looks to be at about one half to one third regular brightness. If I remove the head completely and then screw it back on, it seems to correct itself. It doesn't happen very often or for any particular reason. And, very very rarely, the light won't come on at all (usually with the aa battery packs). Again, removing the head and re-attaching it seems to correct the problem.Originally posted by Chris M.:
Can somebody tell me what this flux or flex problem is with the Arc LS?
It related to the PCB in the light bending under the pressure from the battereis when turned on, that caused an intermittant contact between the ground on the board and the metalwork of the head, making it flicker and eventually quit working. It may also have caused the solder joints of some components to fracture, causding a similar effect.
The first failure mode was the one found to be the most common, and with a little care, the folks at Arc could take the affected heads apart, repair and improve the ground connection so the problem could not re-occur, and re-assemble it good as new.
