Where can I find Lumen output ratings for McGizmo's lights?
KDOG3
KDOG3
Sea Isle City, NJ
I must just be blind or not looking in the right place, but where can I find the output numbers in Lumens of all of the McGizmo lights? Also is the HD45 the only 2 cell light he makes? I'm REALLY starting to like that PD....
Kiessling
Kiessling
Moderator,
Germany, Old World
There are no "official" lumen ratings of Don's lights as Don trusts his IS much less than we do :D !
"Unofficiall" IS results indicate about 50lumens on high for the McLuxIII-PD.
Aleph ratings will depend on LED and driver used, and I cannot remember ratings for the HD45.
bernie
KDOG3
KDOG3
Sea Isle City, NJ
50 Lumens for the McLuxIII-PD? On ONE battery? Thats terrific! What would the runtime be on high and low for that matter? That light is looking sweet. Is he still building them?
T
thesurefire
U.S.A.
I've never seen a HDS best a PD. That puts the PD at at least 60 lumens, if not more.
Lips
Lips
Louisiana - USA
Lion Cub - Ubin High
Chrome PD - Tbin (probably) High
Jil DD with Flupic - Tbin Burst Mode
Lion Cub got warm
PD ran coolest
Jil DD got hot while shooting
Cheers
2
270winchester
down the road from Pleasure Point.
It depends on what bin is used in the PD.
FOr exampe, my PD has a TWOJ driven at 500ish mAh, which puts it around 50-65 ish lumens at the emitter. But after the optics inefficiency about 35-45 Lumens. The HDS 60's are worst case senerio measured out the front, since they are more likely to be T bns driven at spec or slightly above, they will be brighter than the PD on max output. I have seen my HDS U60 beating the PD without a question, but because od the reflector used in the PD it has superior reach and thus may seem more powerful, but I assure you the HDSs are more likely to be brighter than the average PD as far as pure flux is concerned.
Then again, DOn never intended the PDs to be wowsers. THey are simple yet state of the art practical lights for those who are happy with the specs. It's not a LionCub whose poor LuxIII is driven to K2-level to satisfy the light-meter whores.
However, if you are talking about a UX1K or other custom emitters powered PD, then all bets are off. Someone out here probably has a wonder LED like a UWOJ in their PD driven to 1 amp and can **** the snot out of a U85, but then we have to see a show down to believe it, don't we now?
Kiessling
Kiessling
Moderator,
Germany, Old World
You mean the initial McLux-TK ... the mother of all custom light?
Less than that ... significantly less .... it had a Q-binned LuxI low done at 400mA and a relatively inefficient reflector compared to what Don uses now. But of course I don't hacve exact numbers.
bernie
Similar threads
W
Replies
1
Views
1K
Timmyb
T
nbp
Replies
67
Views
11K
pjandyho
pjandyho
Minimoog
Replies
22
Views
1K
Kiessling
Kiessling
