2xTrinity
Essentially, I'm going to be building a much larger version of the Time Fountain
concept pictured here with a few other guys. Basically, a fountain with fluorescein in the water, lit up by strobing UV lights in order to make it look like the droplets are frozen in midair.
As an alternative to wiring up tons of 5mm LEDs, my idea to get a few high power emitters, with narrow-angle TIR optics, and position them around the "faucet" at the top of the fountain, with the beams aimed straight down. This would cause the drops, and the water in the basin of water directly below to fluoresce. I would then do my best to eliminate any and all line-of-sight spill from that section using some sort of black baffle to prevent direct line-of-sight to the bright emitters.
I know that both UV and blue light will cause fluorescein to fluoresce, so does anyone know where I might be able to find either one in a high flux emitter?
