ok ok, here is your ruddy pics
this poor light has been modded so many times, they need to stop changing leds on me .
its one of these thing, 2.5oz total, the asperical lens added a bit to the weight. there was nothing wrong with the original optic, and it worked ok with the Cree, but i wanted to stop the Spill , mainly.
http://www.flashlightreviews.com/reviews/coast_round-up.htm#LL7847
there it is Glowing, after a glow charge
i shred what was left of the original, this thing had been modded before.
i had to HEAT up the head, Viciously agressivly torched it on the stove, that is why it has a different texture now.
you can see the asperical lens jammed into the end
the heat sinc (or whats left of it ) is turned upside down, so to achieve the focal distance for the lens.
then a cree emitter is Soldered into it, after reaming off the positive connetion underneath.
a resisters legs are covered in heat shrink, and passed through to what used to be the emitter side.
( the lux3 emitter i had in there, was stuck down so good, i just burned it out on the stove)
the other side of the resister is covered with heat shrink insulation, and its jammed (literally) into the emitter hole
the curcuit board, which has had all its parts and pieces tossed out long ago, i am looking for a place that connects to the spring.
Connected the resister to the point that goes to the + side of the battery via the spring
ya like that, or somethin
test it 400 times, then ened up shorting it out anyways, and slap the sucker together, tune it up a bit, and there it is. 60W incadescent resessed lighting in the hall there, and the color of it comparabley (to the camera)
some shot up the stairs, to a PIC, past the led xmas lights. its about 20 feet away
it is being compared to a standard MAG 2D focused as sharp as it goes.
its driven at about 2W.
shooting across the room, cant guess which is the mag huh
mostly there is only the round spill you see in the last pic, the banister is being light up by 2 x60w hall bulbs not the light.
ohh, hey would help to know the power source
its a simple resistered Li-Ion 14500 , runs forver, with dwindling output. its really hot for a long time, and basically never dies, just gets dimmer and dimmer, then ya recharge it.
remember this light is only 100mm long, and 23mm wide at the head, just a bit fatter (at the head) then a fenix.
hey fenix, duhh, how about i campare it to it too.
