Where to get aluminum?
pedalinbob
Michigan
I am wondering where to get thick bare aluminum plate to create heat sinks...
any ideas?
thanks,
Bob
Aluminum cookie sheets are available anywhere, but a sheet metal shop might be cheaper and solve the problem of making nice looking cuts and bends.
Most hardware stores have a "SteelWorks" display that has aluminum sheet stock in it also. Look for the 6/8ft lengths of aluminum stock about 2" wide and 1/8 to 1/16" thickness.
Home Depot is probably a good bet... It's worth the trip just to get some evil ideas while wandering around.
Scrap yards or metal recycling places are a good source, used to get alloy plate here, that was off cuts from manufacturing,some offcuts were a couple of feet square!
Try looking in yellow pages for non-ferrous metal dealers.Best to visit them around lunch time, take a big packet of biscuits and ask the guys in the yard for offcuts or scraps.
Adam
Define - "thick"
some folks call .060 sheetmetal "thick" - I don't start to call it thick till it gets to .5. Up to 1" thick is fairly easy to get - beyond that.....
I used to use aluminum cookie sheets, but the only ones I've seen lately have a non-stick coating. I went to Home Depot and got an aluminum push plate that is used on swinging doors.
thanks for all the help--i found a lot of possibilities!
by thick i meant .25 inch or more...
thanks again,
Bob<---gotta get better at searching the web...
I bought some aluminum flat bar at Home Depot.
And I also saw some cast aluminum "feet" for deck posts at True Value.
Aluminium is used in partitioning as a strengthening agent. As my company re-organises itself on a regular basis, partition walls are aslways been hacked about and there are often skipfuls of aluminium extrusion offcuts to be had, some pieces 3 or 4mm thick!
