NAW
- Joined
- May 18, 2006
- Messages
- 739
Light-edge.com is out of stock on the wa1160 bulbs, so is there anywhere else i can buy this bulb?
B.T.W. its my first post
Blazer said:Been using my MagCharger with the wa1160 for about a year now and I love it, great for on-duty use, love the long throw and wouldn't want to compromise it with frosting or textured reflector (I can live with the less than perfectly round spot). The rechargeable aspect is the best part, just throw it in the charger after a shift and it's ready to go next time (I'll remove it after it's charged fully for 24 hours)
My only complaint would be that the durability of the bulb in the socket is less than ideal. A good whack against something hard tends to offset the bulb from the centre. I've tried spreading the prongs, which improved the stability of the bulb, but still isn't ideal.
I picked up a SL 20-XL LED and it tends to be more durable but less throw and wider spot.
voodoogreg said:As an LEO If i were you i would also suggest making or having a stick made for your MC out of nimh "aero 1/2 D batt's run's longer, brighter, not as much worry if you forget or want to leave it on the charger. It really makes it even more useful. try here: http://www.batterieswholesale.com/nimh.htm You'll want the
Industrial Fast Charge/Discharge Ni-MH's. I have a a stock stick and the Aero's so i don't have to deal with a dimm light ever.
Yeah, getting the bulb straight is pain, I am not sure about the newer ones, but my old MC even when set to spot has a LOT of spill, don't know why. Something my 2D won't do. VDG
jdriller said:You will have to cycle it a few times before it will reach its full potential.
