rwolff
I currently have a Dorcy 1xAAA LED light, but after a bad experience yesterday (went to use it and found that the tailcap had screwed itself down - battery dead and leaking) I'm looking for something better.
Clearly, the "leave it screwed on loosely" tailcap switch design is a bad one (it can either unscrew, or screw down and turn on) for a flashlight which will be attached to a keyring. Lights I've been considering are:
Arc AAA (body appears to be made of unobtainium instead of aluminum)
Peak Matterhorn, Arc-style body
Peak Matterhorn, "ball end" style body
Mag Solitaire with homebrew LED conversion but retaining "screw head down tight to turn off, unscrew partway to turn on" switch mechanism.
Any other LED 1xAAA that I haven't heard of (yet)
What sort of experience do you guys have with these lights when carried on a keychain? I'm looking for something that's "dunk-resistant", won't turn on accidentally, and won't disassemble itself accidentally. The "ball-end" Matterhorn looks like the keyring attachment might unscrew from the flashlight, but for my purposes this would be more of a "safety valve" than a failure (since the flashlight itself would be intact, rather than having its tailcap come off and allowing the battery to fall out or pocket lint to get in).
