Which Zebralight?
User100000
I would like a survival reading and general tasks light and was looking at the zebra lights and some 2xAA headlamps such as the Fenix HP01 and HP05 which only go down to 4 lumens and Belem is probably not as good as the zebra lights for reading but I like the
HP01/HP05 2 x AA vs zebralight low modes for reading...?
My main point is ‘which zebra light?!?’
tonkem
Frisco, TX
Zebralight does not make a 2 x AA light. But they have quite a few headlamps to choose from, in different batteries and tints. Personally, I prefer the 18650 battery headlamps, for the extended run time and output. But the 1 X AA headlamp is good as well.
User100000
I prefer the AA for survival...
But I was talking about the Fenix HP01 and HP05 until I realised the reading light was red.
I would prefer a torch that has 2x AA over just 1 battery I think.
I think I prefer the HM50R to the zebra light...
NPL
I highly recommend the h53c with some DC Fix on top of the lens. It will give you a very similar beam pattern to the h53fc, but if you need the extra throw for outdoor use, you can at least remove the tape and get the best of both worlds with just one light. The warmer tint of 4000k is easier and more calming on the eyes during night use, and the high cri will give accurate color rendition. Overall the AA Zebralight are amazing. They are tiny compared to 18650 versions and really light on your head.
gurdygurds
What type of DC Fix do you use? I was looking Amazon and the only thing I found was rice paper pattern DC FIX.
NPL
I bought my DC Fix at Home Depot, model [FONT=&quot]Model # 346-0211
Here is the Amazon Link:
[/FONT]
https://www.amazon.com/d-c-fix-346-0211-Decorative-Self-Adhesive-Window/dp/B007B9PNOQ
Has worked super well for me. Seamlessly transitions spot into Spill which is fantastic for close up use.
gurdygurds
Thanks NPL!
I bought my DC Fix at Home Depot, model Model # 346-0211
User100000
Re: Which Light for reading and general tasks
I think I want a longer battery life than a 1 cell.
What do you think of the Fenix HP01 and HP05?
MX421
Texas
If you want longer life in a headlamp, i'd second the recomendation to go with a 18650 format light. They are rechargable (so are eneloops i suppose) and the power per weight ratio is much better. Make sure you get a protected 18650 cell.
As for Fenix, I have a Fenix HP12 (i think thats the model). It also is a 18650 light, but with a battery in the back (probaably similar to what you are looking at with 2XAA). Once i got a zebralight, i haven't used the Fenix much since. I keep it as a loaner. The tint is not warm enough for me, but i do like the balance of having the battery pack at the rear. The Zebralights are light enough that its not that big of a deal, but even they are still front heavy comparitively and require the strap (if you use it) to be tightned down to where it gives me headaches over long periods of use. I put up with it on the Zebras because
1) i like the fact that they can be used separately (other models are similar in this regard) and it doesn't make the light so specialized that it can't be used for EDC
2) the tints are much nicer and now they have hi CRI to boot
3) my H602 with its wide beam blows the tighter beam my Fenix uses for close lighting everywhere i go (any mule would work in this regards i suppose)
4) The build of the Zebras is a whole lot better that I've noticed.
lightfooted
Thing is, you're not really gonna get longer life in a 2xAA vs. 1xAA unless you could find some light that is using a boost driver and simply powering it from a pair of AA cells in parallel but I don't know of any that specifically do that. Most lights that operate on a single AA cell do so for weight savings and availability of the cell. The 2xAA versions are usually designed to operate at a higher output, not a longer run time and therefore would not necessarily give you more run time just because it has twice the number of cells. Yes the higher voltage of a pair can mean it will operate slightly longer because the higher voltage means a lower current draw from the LED but unless it is specifically designed for runtime...I'm not sure you will notice a difference.
I too would recommend going with an 18650 for runtime.
MX421
Texas
One the first point he could run at the lower levels and extend his battery life, but as stated above i'm with you on the 18650. 2 AAs weigh about the same for about a third less power. Its a whole different league.
NPL
+1 on 18650 if you want more battery life.
+1 on better led options like warmer tints and high cri with Zebralight.
If you are getting a headlamp that you plan on sharing or lending to friends, Fenix might be a better option as the user interface is more traditional to what most are used to. If it's for yourself, spend the extra cash and get the Zebralight. Once you learn the UI, it's really easy to get to the mode you want and you can customize the each setting to suit your needs.
User100000
I’d like to stick to AA as they’re easily available.
Which zebralights have a warmer tint and ​without a hotspot???
tech25
Near the Big Apple
the H5.. series are the AA's.
Without ANY hotspot (pure flood) is gonna be an H502 series. H502w is 4400k and H502c is 4000k.
With a diffused lens (hotspot blended into spill- but still visible) it would be an H53f series. H53fw is 4500k and H53fc is 4000k.
User100000
Fenix don’t currently sell an H502C, do they?
I just got an email from Fenix recommending the H502D for flood beam and neutral tint, also AA. What do you guys think?
Keitho
CO, USA
I have a few older H502's (pr, r, and L2), which always shock me at how small and light they are. Backpacking for 1-2 nights, that's what I take. Most of my friends who I meet for outdoor walks use 2xAAA and 3xAAA headlamps that look absolutely monstrous next to my little ZL. If I were buying new now, I'd probably go with the higher CRI H53Fc for an extra .1 oz and $10 less.
User100000
It’s definitely going to be the H5 series I’m interested in (thanks).
i can’t decide between the H502/H502D
