Hi,
I hope this thread is not against forum rules , if it is please remove.
I need to build some new fog lights for my car but the space I have now is only 4 to 5cm for the optic diameter and more less the same 5 or 6cm for the heat sinking and circuit at the back.
The idea is to run a SSC P7 led or even a SST 90 in a proper heat sink with a lens capable of making a perfect flood. Also add a good regulation board to run it the most efficient way.
The bad part is that I dont know if I have the skills to do this. I can make the piece to install it at the car but I dont think I am able to build a proper light ( remember it needs to be water prof and 200kmh mosquito prof )
Hope to have some input of you guys.
Regards,
Regards,
