Glock27
Why would there be a time component in IPX standards? I would think that an O-ring would seal to a certain pressure regardless of how long it was at that pressure.
G27
G27
A lot of water seals need time exposure before they fully leak, like a slow leak in the "U" catch under a sink.
Dive watch water resistance standards have always had a time exposure element.
I would think that it is that water is eventually traveling Around and Not Through the O-ring.
G27
Most O-rings are made from NBR rubber, so they may be permeable for some gasses (small molecules) over the longer period of time (days/months), but water passing through them is not an issue at all.
Cheers,
Tam
Repulsion btwn polar and non-polar molecule?
Theres some method, this is 1 of themMadness to even suggest this of course but product testing takes time.
Testing equipment is expensive and testing lab time is expensive.
Given that it is likely rather difficult to determine whether a product has leaked under test during the test (unless the testing rig is sensitive enough to detect ingress which I doubt), if the test took too long then it would take ages to put a product through testing if the goal was to balance water-proofness with other characteristics such as ease of threaded component rotation, performance under a range of temperatures etc.
