Hello,
I did some brief searching, so I'm sorry if this topic has come up before.
What makes CR123s (and RCRs) so great? If I look at the specs on the batteries themselves, I see:
RCR123 (3v) as being 3v @ 680mAh. = 2040mW
However, I see a standard NiMH AA as:
1.2V @ 2600mAh. = 3120mW
So, a AA NiMH has more mW than a RCR123 battery.
The same goes for a AA Primary vs a CR123 Primary. The AA has more potential mWs than the CR123.
So why the craze to use CR123s for lights, and not AAs?
This question came up, when I noticed that my Pila GL3 light does NOT like RCR123 batteries. If I put primaries in, it'll work fine. If I use my RCR 3Vs in it, it'll run full brightness for about 2 minutes before it starts to ramp down in brightness. I would guess the load of the light is too great a demand for the current requested from the cells. Is there a formula one can use to determine the current draw necessary to power specific bulbs?
If I'm mainly concerned about runtime, and I really want to use rechargeables, should I be looking at 18650 based lights, or something else entirely?
And I had a question about protected rechargable Li-Ion batteries. If The flashlight is regulated, is it still necessary to run protected cells? None of the RCR123s I have are protected cells, so I try to make sure I never run the batteries too long in between charges.
Thanks a lot,
H.
Thanks a lot,
H.
