deusexaethera
Banned
- Joined
- Jan 21, 2009
- Messages
- 504
They look like just any other NiMH batteries. Can I get a short list of reasons why they're the preferred NiMH batteries on CPF?
Well, that pretty much settles it then, doesn't it?Low Self Discharge
higher voltage under load
lower internal resistance
higher tolerance to abuse and neglect
test at or better than stated capacity
deusexaethera - "Have they figured out how to make a true 1.5v NiMH yet, or are eneloops 1.2v like all the others?"
I love the Eneloops and use them whenever I can but it would be Really great if they could make them 1.5V.
Does anyone know what is preventing Sanyo and other LSD battery manufacturers from making them 1.5V?
Yes. They're making NiMH cells, and those are 1.2V/cell. Each chemistry has its own voltage per cell, and there's not much you can do about it. (The electrochemical potential is actually something like 1.3V for NiMH, IIRC, but you always wind up operating below that due to internal resistance, if nothing else.)deusexaethera - "Have they figured out how to make a true 1.5v NiMH yet, or are eneloops 1.2v like all the others?"
Nominal cell voltage is determined by battery chemistry. Lithium Primary ~ 3 V, Lead-Acid ~ 2 V, Carbon-Zinc / Alkaline ~ 1.5 V, NiCad / NiMH ~ 1.2 V, Silicon Solar Cell ~ 0.5 V, etc.
You mean the CR AA which is 3V AA size lithium?While lithium promary CR123a batteries are a nominal 3 V, aren't lithium primary AAs (E2s or L91s) something like 1.8 V, and 1.6 V under load? Why is that? Would it be possible to make a 3 V AA lithium primary cell? (I guess there is some very basic, practical reason this isn't done. And sorry, I've gone OT.
BTW, I really like the Eneloops. But how did they come up with that name????
Low Self Discharge
Lithium primary CR123 and AA's are of a different chemistry.
CR123 lithium primaries are Lithium Manganese Dioxide
AA/AAA lithium primaries are Lithium Iron Disulfide
They do make AA size 3v cells, however most of them are intended for very low drain devices. You can get them over the shelf (two of them) by taking apart a CRV3 cell.
Accordin to sanyo, Eneloop = Energy + Loop.But how did they come up with that name????
