Why are HDS (RA) lights so popular?
Re: Why do you guys like HDS (RA) lights so much?
:mecry:
I like the big ugly clips. They sit deep in the pocket. The slide on bezel down clips leave the whole tailcap dangling out of your pocket. I have a ti moddoo clip like the new HDS clips and I put it on a twisty since they don't have screws. Maybe moddoo or wvaltakis or somebody can make a deepcarry slide-on clip.
I didn't mean to offend the MOLLE HDS clip fraternity :grin2:
BTW, Chip will be doing a Ti clip run very soon that will fulfill your deep carry needs. Check out the Customs B/S/T section.
I agree with most of the comments by the other owners but I'll add a couple of my specific thoughts. I purchased a High CRI clicky a few months ago after researching things on this forum. I realize there are other high CRI lights but I don't think there are many and that uniqueness was one factor for me. When using it outdoors the advantage of high CRI is quickly apparent. I've gotten into digital photography the last few years (having kids leads to much more picture taking) and dealing with White Balance (WB) has made me much more aware of color temperature and the like. The difference between the flat, greyish, washed out look of a tree lit by a high powered, high CCT LED vs. that same tree with the high CRI is surprising. I realize high CRI and CCT are 2 different (but related) things but the point remains.
Regarding style, feel, design, fit and finish, etc, I think my view is little different from a few others here. I don't actually view the HDS Clicky as a particularly ascetically appealing light as far as shear beauty. I have Peaks that I think look better and my Mac's EDC in brass is much prettier (to me at least). I do think the HDS EDC's design is beautifully functional. The thick wall aluminum tubing is tough and light. The knurling and anodizing are very functional and I don't worry about scratching this light like one of my brass lights. The stainless bezel (in my case) is extra tough (compared to Al, brass, etc) and protects the vulnerable parts. The crenelations are great for seeing if the light is still on (I know many other lights have this). I use the beacon option that dimly flashes each 3 seconds. I do this just so I know the light is still working and is ready to go. I know it sounds cheesy but i think of this as a "heartbeat" and it is reassuring to see it when I open my bag.
With all that said I think the biggest thing to me is the "dynamic range" and the UI. I didn't think the range would be that big of deal to me but the more I use the low modes the more impressive it is. After reading a thread on how people have their Clickies setup I changed a few settings and now have the following setup:
  • 1 click - ~.1 lumens (forced to start on the triple click setting)
  • double click ~1 lumen
  • double click again ~10 lumen (double clicks toggle between 1 and 10)
  • hold or click press hold - max 100 lumens
  • a slow double click (off then on) gets me back to .1 lumens any time. The .1 lumen setting is actually the triple click setting but I don't have to do a triple click to access it this way.
The only thing I would change would be for a constant press from off to go straight to the max setting as a momentary. The momentary works but it goes to the forced super low triple click setting. It's not that big of a deal for me since I would rather the light came on super low to preserve night vision than have instant access to max high.
So at any time using a combination of fast/slow/holding double clicks I can get a range of 1000 (.1 to 100) broken down in meaningful 10X increments. I suppose there might be other lights out there that can do this but I haven't seen it. Sure my Mac's EDC puts out much more on high (1.4A >300 lumens?) but the lowest of the 3 levels is still so bright that it barely qualifies as a low compared to the HDS.
Since the original questions was "Why do you guys like HDS (Ra) lights so much?" I'll add my last personal point. They are very much an American product. They do source some components from overseas but the vast majority of the engineering, fabrication, assembly, and testing is performed in the US. That is issue for me. I essentially get paid by the American tax payers and feel it is appropriate to buy American where possible. This is obviously a personal point and wouldn't really apply to the many non-US citizens on this board. I have to admit that I don't even really look at the many non-US made lights regardless of their reputation. I can't keep the various brands, models, etc. straight but I do understand that some of them have significant followings. If there is something that does all the things the HDS Clicky then that might be an option for others. For me the price difference isn't that big of a deal. As someone pointed out earlier, I just spent $140 for a pair of high quality (US made) running shoes that will last 3-6 months of actual use. The HDS Clicky will obviously last much longer than that.
I think my best summary would be that the HDS Clicky is the one light that I have closest to me most of time and I never hesitate to grab it wondering if it has enough power, too much power, worry about scratching, etc.
Hope this was helpful.
-Rich
Bravo !! That's a well thought out and articulated post.
Damn, now I'm really torn between my curiosity and my wallet... AGAIN!
lovecpf
Quote: If that thing had a momentary tailcap as well it would be the perfect light and I could sell most of what else I have.
It does. It does dang near anything you want it to UI wise. You can program it to work as a momentary and a clicky. At the same time. Press once for constant on. Or, press and hold for momentary. When you release it turns off. All at the same time!
I realize the versatility, but I meant a momentary in conjunction with the twisty. So that it would work like a McGizmo PD with three levels.
I guess what I'm really saying is that I want a proper PD light that I can buy. 😱 I'll stay out of this thread now..
Wow! I started this thread and then had to go to a clients. I'm back and this thread has taken on a life of its own:thumbsup:. I just read the 3 pages of info but I do have a question. What is the tint like on the 170? I am really becomming a tint snob. The older Zebralights are too pink for me and the new SC60 is too blue. Quarks are too green. Cool Fenix lights and Dereelights are WAY to blue/purple to me. I need a neutral tint but noticed that tint is only specifed for the "140 guaranteed tint" model which is 5700k - 6300k and that sounds too cool for me. On the other hand the high CRI is 3700k which may be a little warm and it is only 100 lumens. Does HDS offer a Neutral (~4500k) 170?
The tint is greenish for me. Perhaps I was lucked out on the tint lottery.
The way I set up my Clicky is to have instant access to my main setting from off - momentary if I hold the button down and on if I simply click it. For max I just do a quick double click and there it is, every last available lumen in an instant.
One thing I want to caution anyone who may purchase this light for tactical/military usage is the 'momentary' is slow to come on. (2nd momentary mode, click, press-and-hold) By a few milliseconds, but I can feel it.
Using it in any other situation doesn't bother me (eg, volunteer first aider and firefighter). But when bringing the light out for FIBUA (military reserves), I'd not take this light as a primary light.
One thing I want to caution anyone who may purchase this light for tactical/military usage is the 'momentary' is slow to come on. By a few milliseconds, but I can feel it.
I don't know if there are differences light to light, but mine have been instantaneous to momentary, taking a moment longer to the max mode. I would make a couple changes from my EDC programming, but considering that the Marines are carrying Henry's lights, I think they're already military approved.
The Osram GDP is a bit special in tint, difficult to explain and there are variations of course. I have a 170Cn (currently getting a new emitter, my fault...) and a Ti Clicky. Both have the same emitter, but I guess those for the Titaniums underwent a severe selection process.
So, my 170Cn was rather cool, white in the hotspot, changing to slightly yellowish in the corona to become purplish in the spill, on the edge of the beam. It is not that tinted as different Fenix lights, the light is still white! I see this phenomenon on other lights using the GPD as well.
My Titanium on the other side is also white, but slightly yellowish tinted, you may say golden, as it is an expensive light... Side by side, the Titanium looks much nicer, it is a tick brighter as well, the hotspot is better defined, the one on my 170Cn was somewhat blurry, it was while trying to fix that, that I broke the ceramic (or whatever it is...) around the emitter.
Let's also say that my 170Cn is from 6/2009 and I'm curious how the beam wil look like with the new emitter.
There's actually no neutral white from HDS, perhaps it'll come? The P4 look slightly warmer to my eyes. My 140 GT looks nearly exactly as my 140C, which means that I was lucky with the 140C. Of course the light is white, to my eyes slightly yellowish tinted in the spill. The high CRI is yellow to orange and the corona is even brownish, going back to yellowish in the spill. I often say that the high CRI has like a brownish ring around the hotspot. This is white wall hunting, the high CRI is made to be used in nature, where it renders colors perfectly.
All this is difficult to explain, you need to search for beamshots and those vary from screen to screen. To be honest, only seeing is believing! :wave:
No difference light to light.
I'm referring to the 2nd momentary mode (click, press and hold, release).
The 1st momentary mode doesn't have a delay (click, release)
Of course, you could program it to come on at full brightness (press and hold).
The delay is inevitable due to the UI interface itself. If you were to simplify the UI you would solve the problem - but then you wouldn't have so many modes also. An acceptable compromise.
Military approved doesn't always mean it's the best. Eg, the classic anglehead torch. I've seen this firsthand.
It has to have a "best something" to stand out. Bimmers are known for "best handling". I don't have a HDS, but from all the posts above, looks like the HDS have the "best compromise" i.e. the most # of desirable features by the most people.
May be they "listen to the customers"?
Actually...the new Mustang runs right with the M3 around the track now. 😛
No, I think "buy one, to see what you're missing" is more effective. And it's why I'm ordering my first HDS Clicky today. :thumbsup:
Congrats! You won't be disappointed.
I like these threads, usually the owners are very outspoken and anyone reading will quickly know what's so great about x light.
My wallet doesn't like them though, they've resulted in over half a dozen Surefire A2s and a Surefire M6 now. :fail:
Yeah, these treads can definitely be dangerous for your wallet. 😀 But aren't you glad you bought the A2 and M6? 😛
As far as cost is concerned, yes it is expensive. However I have found that by owning these lights (I currently have the 170 and the CRI) I have actually spent less money. Prior to their purchase I was buying 2 or 3 $50 lights a month. Problem was that I was not really satisfied with anything I purchased. Once I bought these I was happy. I find the lights very similar to Chris Reeve Sebenzas. True top of the line production pieces that are as close to perfect design as you can get. Neither are the smallest, lightest, latest, greatest, etc but the sum of all the parts exceeds anything out there.
As for which to buy first the 170 or the CRI. I would go with the 170 then the CRI.
This reconfirms that I'm going to have to save up and eventually just buy a Sebenza. I hear nothing but great things. It's like the HDS EDC of knives. 😀
I was one of those who don't look at ra clicky. After reading "must have" list and many discussions i became very curious about this flashlight. On the other hand i was looking for high CRI.
1+1=2 i just bought Ra clicky high CRI and now i can understand 😀
Don't worry about numbers.. this light is powerfull and i like it for its color rendition (but it's just my led), for its strenght feeling, for its perfect beam, for programmability and finally i find it very very ergonomic. I have a medium sized hand, i feel it as "my flashlight".
It has only a great defect... i would like to see with eyes the 170...
I too was never really that interested in the Clicky and didn't understand what all the fuss was about. But, I had desired a high CRI, non-homemade/modified flashlight for quite a while. Once the high-CRI P4 became available, I had to get one. Not only do I love the emitter, but now I completely understand why everyone loves these lights! 🙂
Then it can't be an XP-G R5. What is it? XR-E R2, XP-E R2?
If drawing 1.5 amps it should get very hot.
When they are I might be interested in one! I love overdriven lights. Max isn't meant for 20 minutes of straight use. Give me 280 lumens for 5 minutes of fun along with that 170 lumen mode for longer duration needs. Even then I wouldn't spend $180 but I would go around $95 for it.
I know the titanium version goes for a fortune but that doesn't mean it is worth it. I'll take my titanium Quark with a 1.4 amp driver mod. Just as pretty - brighter - nowhere near the price. But as I said...for me it is a tool to light things up - not a work of art. That's why I don't get spending 10 grand for a watch when a $100 watch keeps time more accurately.
You might be forgetting that when your power source has a lower voltage than what the emitter requires for maximum output, the batter will need to make up that deficit by supplying higher current (via the driver). Tailcap current does not necessarily equal current at the emitter.
So, why do I love my HDS EDC High CRI:
  • High CRI LED - Color rendition, tint, and beam quality is a must for me.
  • Small - While not as small as some other lights, it fits perfectly fine in my left front pocket for EDC.
  • User Interface - While the program does take a few minutes to initially figure out, have the ability to customize it exactly how you want is great.
  • Build Quality
  • Warranty and Customer Service
Also, after owning my HDS EDC, I've learning that it really takes A LOT of light to really make a noticeable difference. The brightness steps on the Clicky really demonstrate it well. I barely notice when it steps down from 100 to 70. When I click again to reengage the max mode, I am usually surprised by how little difference the ~42% increase in brightness is.
With this being said, if a Clicky 170 had one more step up, it would put it at ~240 lumens. Honestly, I don't think it would be very noticeable based on what I've learned and seen. I think your perception of brightness would be more influenced by beam pattern when comparing to some other light than the true output difference.
I love my High CRI Clicky, even with its measly 100 lumens. As carrot once pointed out, Brightness Isn't Everything. 🙂
Some very well thought out replies - and some interesting angles and perspectives.
I'd like to augment a few points already made.
Bandwidth. I'll admit that back in the Arc 4+ and B42 days 4 levels felt a little bit like overkill. I mostly used mine as three speed lights at the time because the visual difference between levels wasn't significant in daily use. It was nice to have but not essential. I would argue that with modern emitters and north of 100 being standard that 4 levels are quite useful and I use all of them regularly. McGizmo has argued as much in his design decision to move toward three level light designs and away from the two level PD (I know this is more complicated but no question modern emitters make three levels at minimum seem quite useful). Still many lights manage wide bandwidths - some of them with quite nice programming (the LF3XT comes to mind). Which leads to...
UI. How you access these levels impacts the overall utility of the light for any individual user. The HDS "multi toggle direct" approach really is unique and the ability to customize how it interacts is both simple and able to create a very unique experience for the user. The LF3XT in my opinion comes closest and it still isn't as user friendly in my opinion. While this may not matter to some - it matters a great deal to me and I have been and continue to be very devoted to this UI. Once you use it for a short time it is quite intuitive and handy. But that depends on what matters to you as a user, which leads to...
Utility. I've liked what some have already said about this matter and thought I'd throw my spin on it. We all achieve a certain amount of "utils" from whatever we do and how we allocated our capital. Our personal utility to capital outlay curve varies by person, and across potential expenditures. Many including myself have something of a plateau where additional capital does not derive additional utils, and in some cases might actually decrease overall utils. I try with nearly every expenditure to find what I perceive to be the sweet spot on my utility curve and I think many of us do the same. We all have multiple principals and guidelines that are inputs to our utility curves.
For example, I admit that I would rather have one or two items that for me represent a higher quality level than many less quality items. I tend to place a higher value on build quality, reliability and longevity for many items. I somewhat devalue status and prestige. As a non light related example, I've owned 3 cars that I purchased totally on my own, an Acura Integra that I drove for 10 years, an Infiniti QX4 that I drove for 9 and a Honda Civic Hybrid I've had for 1.5 years. All were more expensive than some alternatives, less expensive than others and represented the best "bang for the buck" for the kind of vehicle I was looking to purchase at the time. Two of them have been quite reliable (the hybrid is too soon to tell but I admit that while 42mpg on average is nice - I'm having some buyers remorse given the price paid for that mileage in terms of the driving experience and even safety... but that is another topic).
Certain products represent a specific utility curve of their own - what they provide relative to other qualities. Ideally what a product or experience provides somewhat matches your own utility curve for that kind of product or experience. Recdna has willingly said that his utility curve places a high value on total output per dollar. Relatively speaking total output is not the highest priority for Henry. Consequently it is not perhaps the best match for him or for others. What UI you like as Carrot has indicated can also impact the fit - as the UI is a high priority item for HDS and the design decisions in that UI might not fit, or the UI in general may not matter.
What is clear is that for many posting here - the relative design decisions and value proposition offered by Henry and his lineage of lights is a relatively close match for our utility curves! What matters to us and is valued on our curve has been fairly well covered thus far... :naughty:
I will say this as well - Henry is not an industrial designer. I obviously am fond of his engineerng and programming skills, but all the way back to the HDS B and U lights they are flat out ugly. Utilitarian and practical, for sure, but ugly. However, while it matters some to me I'm willing to sacrifice that for function at least with a light. :grin2:
If you use the momentary function and disable the turn on preset, the light will come on the last level used. If you turn it on to high, and turn it off, the next time it comes on will be on high. Or medium. Or low. Or whatever. You can use it as a clicky if pressed once for constant on, or press and hold for momentary.
Mine is set to come about 10 lumens. Double click to med. Press and hold for high. Triple click for the lowest setting. I have momentary enabled and turn on preset disabled.
TeknoCowboy modded mine with a neutral xpg and it's brighter and a nicer tint for my eyes. It looks to be the same brightness as my Quark 2AA neutral at 200 lumens, maybe brighter. I'll call it 200 lumens.
That was my point, that you made it sound in the previous post as if there was a delay on the first momentary mode which is inaccurate and it's good to see you've corrected that in your present post to what most of us owners already know about the operation. Since people are continually using the content of these threads to determine whether or not to buy makes accuracy pretty important in our statements.
The fact of the matter remains that it's not a bad light for military usage and your mention of an ancient light has little to do with Henry's lights. It's understood by all that mistakes are made, but you've drawn a connection between the anglehead light and your assertion that the Clicky is no good for military usage and I simply disagree with you on that point.
Still your opinion stands as what it is, your opinion.
Out of curiosity, what's wrong with the classic anglehead torch?
--flatline
I did't get a HDS (RA) light now,but i will buy one for a try in one day 🙂.
Agreed.
I don't think it's a bad light.
But I do not think it's the best option either - unless you program it in such a way that 'burst' (maximum brightness for those unsure of terminology) is the 1st mode that comes on in momentary. If you do so, you risk loosing one of the selling points of the light - the user interface.
I am not drawing a connection between the anglehead and the clicky. I'm using the anglehead to demonstrate that military procurement is not all that effective and what they purchase is not always the best. I could have used the V22 Osprey as another example, but considering this is a light forum I chose to use a light as an example.
Of course! I'm just trying to warn the original poster of what I find to be a potential issue of the light. Whether he determines my post relevant or not - that's his business.
--flatline
Nothing wrong with the anglehead per se. I do like its shape and ability to take a beating.
My initial assertion was that military procurement may not always buy the best stuff. It doesn't mean that the stuff they bought was inherently flawed either, there could be better stuff out on the market for the same price.
Gonna be a huge dork here -
Anyone ever torture test one of these beside what's on the HDS website? Specifically, I'd like to see if it would stand up to a .45 cal ACP FMJ from 10 yards. Not straight down the head, but from the side. I'd sell off every light I own and only carry these if it made it. :sick2:
-done being a dork now...
Well, this will obviously make a huge dent into the light's body, possibly destroying the reflector/electronics/battery depending on where you hit it exactly.
Quite frankly I think this is an unreasonable thing to ask of a flashlight. :duh2:
