Other way around. T16-size bulbs as pictured on the left are used primarily in vehicles, and also have been used in landscape lighting and vacuum cleaners and similar applications.
Let's say they're used most commonly for cars and landscape lights. I'm not familiar with many models of cars.
Not sure what you mean by "and in places that could fit both these bulbs". It is true that both of these bulbs have the same base and so they are physically interchangeable. However, because of the different LCL (Light Center Length, distance from the base to the filament) they are usually not optically interchangeable.
In many places where the optics are not finely tuned and can use different bulbs (address lights, vacuum cleaners, and landscape lights), I've seen the smaller ones used where a bigger one could fit instead (and maybe spread light even better).
You've got your info all mixed up. Both of these bulbs have a W2.1x9.5d base (or "mini wedge" in US terminology). The bulb on the left is a T16-size bulb ("T" for Tubular glass, 16 for 16mm diameter). The bulb on the right is a T10-size bulb (Tubular, 10mm diameter). The one on the right is not a W5W. It could be a 161, a 168, a 194, or several others. A W5W (and a W3W) has the same T10 shape and W2.1x9.5d base, but has a different filament shape. The bulb on the left could be a 921 (also known as W16W), or it could be a 922, a 916, a 912, or a 906.
Oh, so the base is W2.1X9.5d, not T10. T10 is the bulb. Now I know.
I thought that was a W5W bulb because it looks just like W5W bulbs I've replaced. Apparently there is a whole lot more to this.
Who gets to decide what's "reasonable"? And what information are you basing your decision that $1 to $2 is not "reasonable"?
Reason decides if it is reasonable. :ironic:
$1 or $2 for a tiny piece of glass and filament is ridiculous. Considering you can get the same bulbs for much less if you look hard.
There is no product in the world that cannot be made cheaper and in poorer quality. Paying more money doesn't necessarily get you better quality, and sometimes you can find super deals on good quality product, but in general, quality costs money.
What product are you talking about? You mean T10 (these miniature bulbs) in general?
Yes, in general quality costs money, but their prices often vary. I found Osram bulbs (quality) for about 48¢ at an European store, whereas the same bulbs I find on Google Shopping search are typically 90¢-$1.00
Whoever said a bigger thing should be more expensive than a smaller thing?
A bigger thing would typically be more expensive than a smaller thing because it uses more materials, but because of demand and other variables, many times the bigger things are cheaper.
If the smaller T10 bulbs and the bigger T16 bulbs were released at the same time, made at the same time, on equipment purchased at the same time for the same price, and both bulbs are sold in equal amounts, the bigger one should be more expensive because it uses more materials.
Though that is usually not true in the real world, because of demand and other variables, which is why I thought the bigger ones were cheaper. Larger demand because people buy lots of them for their landscape lights.
No, and it's based on a faulty assumption.
Then what is it? This is the whole point of this thread.
