LEDninja
It seems in every thread of 1.5V Cree -XRE lights, someone wants to know if they can use a Li-on battery in the light. Why are we trying to power 1.5V lights with Li-ons? Should we not just buy a light designed for a 3V Lithium/3.6V Li-on?
All this discussion about 10440/14500 batteries in AAA/AA lights prompted me to dig up Newbie's research into the Cree XR-E again.
http://candlepowerforums.com/vb/showthread.php?t=138503
The 1st chart shows Input voltage vs. current.
3.1V = 350mA nominal 1W
3.29V = 700mA nominal 3W
3.38V = 1000mA max current Cree has qualified the XR-E
3.6V = 1850mA almost double the max allowable current of the XR-E
4.2V is way off the chart into magic smoke territory
I believe the 1st 'production' XR-E light the Aleph A19-XRE has a boost/buck circuit. It will limit the current to 850mA even if the input voltage is 4.2V.
More common are boost circuits that shut themselves down and let the battery direct drive the LED. So at 3.6V we are driving the LED at double what it is rated for and at 4.2V.....
Worse still are dumb boost circuits. They keep boosting so 3.6V becomes 7.2V and 4.2V becomes 8.4V. Yikes!!!
It is a little better with the higher Vf of the Luxeons. At 3.6V the Lux is only driven to 350mA and 4.2V 1300mA.
Under load the voltage may drop a bit and current goes downto 700-1000mA. Can someone with knowledge of Li-ons under load comment on this.
