brightasday
Seems like recent 18650's, e.g. Panasonic, have legitimate 3400mAh capacities. A good 14500 has a capacity of 840mAh (Sanyo), less than 1/4 the capacity of the new 18650s. Why is it that there aren't 14500s with considerably higher capacity?
Just doing basic volume calculations, an 18650 only has a bit over twice the volume of a 14500. Based on volume, I'd think a good 14500 would hold close to 1500mAh.
Is a lot of space lost to the packaging of the batteries, so that the actual material that holds charge is significantly less than the exterior dimensions? Even if I assume, for example, that the packaging takes 2mm of the diameter, and 3mm of the length, the volume of an 18650 is still only ~3x the volume of the 14500. With those assumptions, I'd still expect to see 14500s with legitimate capacities over 1100mAh.
Is it that 18650s are used much more extensively, so they get the latest and greatest technology years ahead of the 14500s?
