HighlanderNorth
I keep reading the specs of all these different lights, and I was just reading another thread here about the FourSevens XM18, and the 2nd poster pointed out, that the FS Maelstrom S18 is rated at 1800 emitter lumens, but only actually puts out 1200 at the front(OTF).
So that means it has lost 33.3% of its brightness in, oh.....about, 1 inch! **I assume its "losing" this brightness because it's being spread out by the reflector in directions other than straight forward like a laser. Thats the only explanation I can figure out as a non lighting expert. Otherwise it wouldnt make sense for an emitter to lose that much energy in that short a space when surrounded by a 100% reflective surface. Maybe if the emitter was surrounded by a black cone shaped object, then some would be absorbed.
##So question 1 is: Am I correct in my assumption above(see asterisk) as to why so much brightness seems to be lost?
##Question 2: Do most LED, or other flashlight manufacturers give you the OTF or 'out the emitter' brightness numbers in their specs? Are there any companies that regularly give OTF specs?
I've seen a couple flashlights where the manufacturer has it stated in the specs that the numbers they are giving are OTE specs, so I guess that means I can subtract about 33% from that number to get the REAL specs.....:thumbsdow
