Battery Guy
I really love my C9000 charger for AA and AAA NiMH cells. It is really great to be able to get reasonably accurate discharge and charge capacity, as well as an estimate of internal resistance, with a consumer grade charger that is easy to operate.
Any thoughts as to why it is taking so long for someone to make a charger similar to the C9000, but for lithium-ion cells? Here are the features I would love to see:
1.) 4-bay charger capable of charging/discharging 14500 through 26650 cells;
2.) Current ranges similar to the C9000 (100-2000 mA charge, 100-1000 mA discharge);
3.) The ability to set the cut-off voltage on charge in 0.1 V increments between 3.5 V - 4.3 V;
4.) An "analyze" function that would discharge/charge/discharge the cell and report cycling efficiency and internal resistance. A cycling efficiency >100% on a lithium-ion cell means that more charge was put into the cell than was discharged, and this indicates that an internal short circuit is present;
Any chargers out there that come even close to doing this at a cost equivalent to the C9000? Actually, I would probably be willing to spend up to $100 for a charger that had these features.
I am not an electrical engineer, so I would be really interested in learning if there is a technical reason why nobody has made a charger similar to the one described above.
Looking forward to your responses.
Cheers,
BG
Cheers,
BG
