Yes, a mule (reflectorless bare emitter, with plano lens, no optic) is the most practical, and beam width will be limited only by the height of the surrounding bezel.
Technically however :devil: one might get even a bit wider beam angle by removing all bezel assembly entirely and running in "candle" mode .... with an LED emitter, this would very closely approach 180 degrees, and with an incandescent lamp could exceed 180 degrees.
Attaching a diffuser "wand" will also provide floody light in a very wide pattern, though it would be hard to consider its output a "beam" of any sort 🙂
There are also "lantern" attachments (such as Solarforce) with an "inverted cone" reflector that actually reflect the beam outwards and backwards ( > 180 degrees) .
