Because the weaponlight has the machined shoulder in there, to keep the batteries from flying forward under recoil, I'm not going to say yes until I hear from someone that has tried it. But I think it might. Sadly, someone with this light (or a similiar SF Millenium series light with the same head) and the actual module will need to try it before you spend money on it. I know that an older Bug-out-gear 3W module will fit in the Surefire "Classic" weaponlight module, but the dimensions are different.
I will say that since the M952 includes the shock-isolated bezel, you'll need a ring that Malkoff sells to take up space in front of the LED module.
Regardless, if you try the M60 and it doesn't work, you will have ZERO problem re-selling it.
Remove the black plastic ring on the base of the neck/shoulder that the poster above me is a referring to. Use the Malkoff washer and it will work fine.
