wiring 6 SST-99 up using 12 volts building a underwater light
JLD
wiring 6 or more SST-99 LED's up using 12 volts whats a good driver's and will i have to have a converter could this be dun for this I'm building a underwater light that will be wired in to a 30 foot extinction cord hooked to a 12 volt marine battery I'm looking for as much light a possible and are the SST-99 my best bet or could i use more of a deferent size/type of LED to get about the same amount of light for less cash
DIWdiver
Connecticut, USA
You'll get lots more lumens/dollar using the XM-L2. You'll need more of them though, so if lenses or reflectors aren't cheap, then that may make the SST-90 the better choice.
There is lots of discussion of running multiple LEDs at 12V in the following threads. You may want to skip to post #100 in the first one, #60 in the second one.
http://www.candlepowerforums.com/vb...tive-linear-13-5A-LED-driver-adjustable/page4
http://www.candlepowerforums.com/vb...-Automotive-3-6-9A-driver-feeler-thread/page3
