Wiring question
Tony_J_Ross
G'day all.
Just about to put together a 4x XR-E bike light and was wondering about the wiring.
Should I do the first or second drawing for a parallel wiring hooked up to a 1A Buckpuck then to a 14.8volt 4400mAh battery.
Ultimately I'd like to slot one pair into low mode with a dimming resistor (Done before on a triple Seoul light). I'm assuming I could do this on the first drawing and not the second ?
Cheers.
OR:
The two circuits are identical. You can put the resistor/switch on either of the middle wires.
However you might find the first easier to wire, putting the resistor on one of the + wires, maybe nearer the driver.
Thats what I did here.
Ah, cool thanks.
Is there much difference between 500mA and 1A in brightness ?
Question comes from my other lights which run 3 in series. Is that running at 1A or other ?.
I want maximum brightness without changing to a new battery since I've invested too much money in the two I have now.
Heat should be fine in the housing I'm making at 1A for a normal ride so heat isn't so much of an issue.
Cheers.
Tony.
Simplest way is to direct-drive all four in series - no buckpuck.
But I prefer to have two spotlights, and two broad beams, separately switchable. So preferably using two regulators.
