old4570
With hindsight , what batteries would you buy NOW ! or recommend to others in CR123A or 18650 ? Heck why not all of them !
I'd go with 14500s and 18650s, skipping CR123As/16340s completely.
So if draw in your lite is below 2A IMR is a bad choice? I am looking at using 2x18650 18650IMRs for the safety reliability factor but they will be in a lite with 1 XPG drawing about 1A. I think I have seen that with these ImRs if current draw is too low they actually perform pretty poor?
Thanx for the input Shine. It helps to see how you approach these setups and your logic seems very solid.
I have always just automatically gone with protected Li-IOns but have found myself wanting the absolute most reliable setup and to me the PCBs in LIIon batts are just one more link in a chain that could be the failure point. If you drop one on the Neg end you could damage the PCB and poof no light. Unlikely but possible.
But I am torn between going unprotected LiIon which could pose more dangers or the IMR . But if the IMR trade off is too large it isnt worth it either. I guess I am wondering with IMR if they are utilized in a lite running a single XPG led and pulling somewhere around 1-1.2Ma will I get reduced output and significantly shorter runtimes compared to an AW Li-Ion prot/unprot. ?
OneBigDay - all good comments and I agree to many of the point but would like to argue a few of these points.
-AA/14500 lights. Single AA lights just don't really get that bright in general unless you can use them with 14500 cells at 3.7v. That limits the scope of viable lights a lot. Also AA lights which do get bright usually use a boost circuit which requires a very high source current (>1A) from the battery. When the light gets hot it is because of the battery warming up and not the LED itself (example: NiteCore NDI - running to empty on 14500 battery only gets slightly warm but the battery gets HOT when running an Eneloop NiM). Don't get me wrong I love the single AA category - just only when using a 14500.
-Problem with 2xcr123 vs 18650 lights is that they usually run regulated on 2xcr123 or 2xrcr123 and unregulated on 18650. There is only a very small subset of lights which are regulated 18650 lights. LG Mini is a great example but ugly cheap LED color and ugly beam - although a great light in all other respects.
-26650 is nice format just not really supported outside of the custom light space.
I started off not being a supporter of the 123/16340 size of battery and was more 18650 and AA. Lately I have been a big supporter of the 2xCR123 lights. Usually they support IMR16340 cells and almost all will support the AW LiFePO4 cells at 3.2v.
There's no right answer here, just personal preferences.
