EDIT 7/8: Added runtime of High mode using LRB-168A
Got this great light from the raffle: QuarterFlash/LumensFactory Raffle!
Thanks Glen C for this wonderful offer! :twothumbs
The discuss thread started bt KeeperSD is here: New Wolf Eyes D2 with 2 level cree - pics/beamshots
I'll just take some photos at this moment, runtime will be upload in a few days.
Spec. summary:
Cree XR-E P4 3.7~6V D26 lamp assembly
Two-stage output: 170lumen/20lumen with HO lamp assembly
80min regulated output for High output (4 hours un-regulated output)
50 hours for Low output
Deep sculptured head bezel:
LED is centered well. The reflector seems to be heavy orange peel.
Included LRB-168A
Apart:
I haven't seen such tube construction before. Double layered? oo: Brass for inner tube?
Head end:
Tail end:
The switch is forward clicky. Soft tap for momentary ON. Full click then release for steady ON and one more click to OFF. Twisty head for High/Low. The operation is simple.
The included WE LRB-168A works fine but I have problem with AW protected 18650. It'll be only in Low mode. I found LRB-168A is slightly longer than AW 18650 and I put a small magnet at the bottom. The problem solved.
Here's some size comparsion:
The output is bright and white! Please refer to KeeperSD's thread for great beamshot.
Here my poor beamshot :devil:
Low mode (M1 on the left, Defender-II on the right)
E.V. +0.0
E.V. -1.5
High mode (M1 on the left, Defender-II on the right)
E.V. +0.0
E.V. -1.5
Lux reading at 1m: High: 2580, Low: 209
My M1 with OP reflector: High: 3710, Low: 772
Here's the runtime of High mode using Wolf-Eyes LRB-168A protected 18650. The marked capacity is 2200mAh. Runtime started with open circuit voltage of 4.20v. Flat regulation about 110min.
Spec. summary:
Included LRB-168A
Apart:
Head end:
Tail end:
E.V. +0.0
E.V. -1.5
E.V. +0.0
E.V. -1.5
