couldnt post in the reviews forum for some reason so heres a quick comparison of these few lights.
http://www.flickr.com/photos/[email protected]/4949273909/
fenix l2d cree, dereelight dbs mce, dereelight dbs sst-50, olight m30, wolfeyes superstorm 2 (R5, 1950 lumens)
http://www.flickr.com/photos/[email protected]/4949867336/
with extension tubes for 2x18650
http://www.flickr.com/photos/[email protected]/4949866708/
outdoor beamshots
camera held direct above the light. first tree trunk on the right is 70 yards, then 5-10 yards between them.
http://www.flickr.com/photos/[email protected]/4949860892/
wolfeyes, mid
http://www.flickr.com/photos/[email protected]/4949269417/
wolfeyes, high
http://www.flickr.com/photos/[email protected]/4949861948/
m30, high
http://www.flickr.com/photos/[email protected]/4949862746/
dbs mce, high
http://www.flickr.com/photos/[email protected]/4949863270/
dbs sst-50, high
http://www.flickr.com/photos/[email protected]/4949272565/
fenix l2d, turbo
impression about torch output
The dereelights and m30 were very similar outputs. spill on the dereelights started 5 meters forward of the torch, spill on the m30 started 2 meters foward of the torch and much larger (approximately double the size at ~20 meters).
there was only a small difference between the dbs mce and sst-50. sst gave about 10 meters more throw at max distance over the mce, could just see things out at about 150 meters. mce version had slightly larger flood but as this starts about 5 meters forwards of the torch it kind of defeats the purpose.
m30 only slightly less bright hotspot than dbs mce due to being much wider and useful spill.
mid levels on the dbs i found too dim, about the same as the 40 lumen level on the fenix. mid level on the m30 was about the same as the turbo level on the fenix rated at 130 lumens, low was about the same as the low on the fenix ~20 lumens.
m30 is the best bike like out of these due to the spacing of the levels and wider spill which lights the road at about 1 meter infront of the front wheel.
wolf eyes was a cavernous wall of light but slightly out thrown by the dbs sst-50 at max distance of about 200 meters.
general impression
the wolf eyes is a keeper even at its £300 price which is comparable to other lights of this output but much lighter. its impressively solid, tank like, well made and stubby, no battery rattle, own inbuilt charging circuit, fits well in the hand and is only about 600-700g (im guessing) with the 3x18650. the mid mode is only about 100 lumens less bright than the others on max and should last quite a few hours, im hoping about 10 hours as its only 30% of the max output. as the mid level is quite close to the others max, im guessing the rating of 1950 lumens at max cant be far off.
theres no memory of the last mode and it doents come with anything apart from a nice box and a long string lanyard (which fits through a non-removable metal loop on the back).
m30 is also a keeper, others have described it in detail so i wont. i love the wall of light the spill puts out and the hotspot is still almost a bright as the more focused dbs mce light. its compactness is great too, its the only one i wouldnt mind edc'ing in a rucksack with its extension tube. its the only one that tail stands too (apart from the fenix). theres a bit of battery rattle with the 18650's. a good bike light, finally i dont have to guess the dark road like with the fenix. i dont see any pwm at all but there is a small buzz u can hear close up.
the dbs lights are ok nothing really stood out to blow me away though. the throw on the sst is slightly better than the mce version and the m30 but not by that much, 20 meters maybe at max distance. theres a bit of battery rattle and no strobe. the tint is on the green side for the sst, blue side/neutral for the others. not sure if ill keep the dereelights, the extra thrown is ok but dont know if theyre really worth keeping just for that slight advantage. the fit of the extension tube isnt that great, its a bit fiddly to screw the switch cap on it and initially i found switching between levels not very sensitive.
outdoor beamshots
wolfeyes, mid
wolfeyes, high
m30, high
dbs mce, high
dbs sst-50, high
fenix l2d, turbo
general impression
