Q
Qship1996
- Joined
- Jan 30, 2010
- Messages
- 466
The size and surface mount appeal to me for my intended application.http://www.rallylights.com/hella-9060-series-duraled-rear-signal-lamp.html
Junk at any price, rather. They glanced briefly at Audi's concept and decided to screw any real *design* and just market this junk to the tuner crowd. Expect to see that junk installed on the same cars with HID kits, full-time front fog lamps, and burned out registration plate lights. Maybe some of the "chase" lights around the registration plate or incredibly way-too-bright LED registration plate lights.PS,what's the deal with all the really cheap rear laser fog lamps I see advertised everywhere for $5-10? Gotta be junk at that price,but is the concept to broadcast a red line of light on the pavement like they do have merit as a rear fog lamp?????
Had the rear fog installed today,shop charged 1.5 hr labor to wire it up including fabricating a bracket to mount to left side under the bumper of the Highlander.They installed a switch with a LED indicator to show when the fog lamp is energized,located in great "line of sight" to driver.I am happy with their work
They are supposed to have more on-axis "punch", but it's also got a fairly wide viewing angle with higher minimum intensities. I'd assume this is a category F1 lamp, with a maximum intensity of 300cd (an F2 rear fog lamp has variable luminous intensity, with a maximum of 840cd (!)).and the foglamp,however it seems very directional to me- standing directly behind the vehicle,it is super bright- move off to the side a little and it is much less so-guess that is normal as it is a E code approved fixture?
That is a good safety upgrade. I a considering that same lamp.
Do you have to go through Virginia's safety inspection?
While not a reguired light, Virginia will reject a rear fog that is not SAE F2.
You just got rep points.![]()
