AWTYD - FM sells a 4 x 14670 with his 1.5 lights. Actually he has two versions. The white version is slightly longer -owing to the longer tail (charging) section. The black is shorter. Both are hard to come by, but the black version much more so. You might PM Varooj to check on availability.
As to sizing, I suppose you could cut the center shaft down to fit your 14650 batteries. Or, your could buy one of Varoog's 8x 14670 holders (a little more plentiful IIRC) and cut it down to fit. Keep in mind that it too has a charging port at the tail.
Good luck with your search.
