Sold/Expired WTB: Build Request for a special LED-Torch
TheGreyEminence
Germany
Hi!
Yes, i´m happy with my Wiseled Tactical 1500, but i´m hungry for more :naughty:
The Light i would like to be build from some talented Modder should have:
- At least 2500 Lumen Output (should be noticable MORE than the tactical 1500!).
- At least 30 minutes runtime on "high"....the more the better
- IF possible, a LOW and a HIGH output setting.Preferable stepless dimming, it it´s possible at all.
The Size of the torch should not exceed the measurements of the Tactical 1500 (using the Holster from the K3500R for this one! Luckily it fits perfect!)
Battery type *should* be Li-Io OR Li-Po, depending on what the builder´s opinion is.
How many LED´s? Well, i think the size i want will limit it to 10 (???)...
Price...Well, i know this will not be a cheap one, so i´m calculating the ready-to-use Torch for aprox. $500+ X.
Now open for your suggestions :twothumbs
Kind Regards
I'd put the stepless dimming at the very bottom of your list. I've got one and it's rare that I use anything but low or high. Getting it to a satisfactory middle of some sort is rarely worth the effort.
I'd rather have a separate switch for (very low), low, medium, high.
However my dream solution would allow the best of both worlds.
An on/off switch surrounded by a lever that did allow stepless dimming.
It would have user selectable detents so you could "click" to the levels you wanted but pick some in between values.
