WTT : U2 head
akula88
Well-known member
BisDak [Area X] ^^.PH
WTT : Wanted-To-Trade
1. Surefire AZ2 Combatlight (used) TRADED
I had been curious about this light, but found no actual use on my rotation. I find the UI not really to my liking, as well as the size itself.
For full declaration -- Unit was acquired early this year from a ConUS user. A bit of a user light with obvious chip on anodizing on the head and tailcap. See photos.
a.) The main LED has been upgraded to Neutral White, dome-type LED. Forgot to ask which was it. It's a bit off-centered, but beam is not affected. Output seems to be around 450-500 Lumens when using KP16650. The 4 side 5mm LEDs appears to be stock. Pls see photo.
b.) Body - Combat grip has been removed by the original user. Was not included when he sent it to me. The two other rubber ring are not as tight as I want it to be.
c.) 2-stage tailcap seems wobble a bit, and rubber boot shows wear, whilte retainer ring has some toolmark damage.
Amenable to split the AZ2 Combatlight into parts, depending on offer
Additional Photos :
Whole light - 3 side pix : https://i.imgur.com/GCiSBgQ.jpg
Disassembled : https://i.imgur.com/MqbHjLL.jpg
2. Surefire U2 Head only ** STILL AVAILABLE **
The LED of this head had been updated with XPL-Hi [email protected] ~5000k by Nitroz. I don't have any other U2, but rotating intensity switch is smooth. Finish condition is outstanding. No obvious chip or wear. I'm actually repurposing the U2 body for another project, so this head has no more use.
3-sides pix : https://i.imgur.com/0H9ZyAi.jpg
head wt body : https://i.imgur.com/YjX0PP1.jpg
Willing to Trade for : Surefire E1e / E1L / E1D body with or without tailcap in good or outstanding condition.
Pls PM or email for offers if you need a higher-resolution photo.
- Amenable to split the AZ2 Combatlight into parts, depending on offer
- Wide value differential can be negotiated privately.
- Just make offer, if interested. Maybe we can work it out.
Thanks for looking.
akula88
Well-known member
3-sides pix : head wt body :
Willing to Trade for : Surefire E-series / P-series parts, etc or SF-compatible parts in good or outstanding condition.
Thanks for looking.
This is still available for trade. Pls refer to the quoted text. Thanks
