windstrings
Re: X60vn 2015 - Lumen & Throw
I can try again tonight, but being over the lake has lots of moisture.
Those shots were about 175 yards and my next point is about 350 but I might peeve some apartment dwellers off... Humm... Oh well 😊
After that it's maybe 1/2 mile and the beam is so bright it's hard to tell in the moisture ...
But regardless maybe I can find a finge target that one can hit and the other barely makes it.
As you know with your headlights at night, of there is moisture in the air low beams is almost better.
But I'll try...
Just from my shining into space it looks maybe 15 percent more throw with same sized beam. But since there is no real target, that's a crappy test.
I really need an slr so I can take single shots and control etc... Otherwise the camera dials itself down but I'll play with settings and experiment.
I have an iso setting too but resolution is much less if I use it.
Here's the problem I have...windstrings - how big is the difference in throw between x60vn and k60vn, because in your beamshots it looks as if the throw was very similar. I ask because the x60vn has 600 lux and k60vn 230 lux.
But I'll try...
