x990 McCulloch (Acro) battery pack rebuild problem (LED stays on)
HummerGuyInFL
Fort Walton Beach, FL
I rebuilt one of my x990 battery packs and now the charging LED remains lit (RED), even when the charger is not attached. I know the battery arrangement is correct since I still have the old battery pack to compare to and it was never disassembled... Voltage is also correct (12v). Any ideas what's going on?
HummerGuyInFL
i also just finished charging the battery pack and once it reached a full charge, the green LED did come on but the red LED remained lit (turned orange). When I removed the charger the red LED stayed on...
SilverFox
Bellingham WA
Hello HummerGuyInFL,
Something isn't hooked up properly. You may want to take it apart and check out what is going on. I have had mine rebuilt without problems, so it can be done.
Tom
HummerGuyInFL
It's wired correctly... There is really nothing to mess up since the only wires I disconnected were off the battery pack (+ and -). I think there is a bad transistor on the internal circuit board. I'll remove the 3 transistors and test them. I guess it's possible one of them were damaged when the cells ruptured. Hopefully I can find an exact replacement.
Papuga
Big Apple
Can anyone help cross reference these transistors?
Q1 reads: C945 P 21E
Q3 reads: A733 P 19E
Q1 is a 2SC945 -NPN transistor
Q2 is a 2SA733 - PNP transistor.
Given the complimentary pair, it maybe a push/pull type amplifier or wired as a switch.
Full datasheets are available online, just google the full part number.
I have seen this pair in several different security systems for charging SLA's and the NPN is usually the weaker of the two.
Test using a DMM on diode test and look for 0.6V in the forward direction and open or 1 in reverse. If you get the same reading in both directions the Q is bad. Be sure to check E-C for internal shorts as well
If you need replacements, Mouser or Digi-key are good places to start.
Good luck.
Papuga
Big Apple
Transistors were delivered but they're marked:
A733P
W 24
They're suppose to be 2SA733... Are they the right ones?
Don't worry, they are the same. It should work fine as most likely, they are wired in a switch configuration.
Good luck
HummerGuyInFL
Thanks for your help! Installed and everything is working properly...
P.S. If anyone ever needs one of these transistors just message me. I ended up buying 50 pack for $3 so I have 49 extras; lol.
