Wurkkos
XHP70 2X15270 Mule
DUMDUM
Well-known member
Louisville, Kentucky
Well guys we found a board to fit the XHP70 that is small enough 16MM to fit in the new torch.
We do have to make a larger heatsink so the unit will be about .20 inch longer, but that will
bring it in at about 3 inches in length .80 inch in diameter with about 2,500+ lumens in output. Chris said the beam looked good
in a mule, so we will go ahead with the torch, also we are going to make it in dragon body. There
is still much work to be done so we will keep you all informed, I'm from the south. We are also
working on another XHP70 mule a little larger and more powerful, I'll bring you up to speed as
the progress becomes a reality.
Thanks
Bob
