XM18vn Project DONE DONE DONE
Candle Power Flashlight Forum
Help Support CPF:
To get 600k Lux he'll need 33k per reflector which seems extremely doable just by overdriving them but ESPECIALLY if he de-domes them all.
Will you be swapping emitters or are they already XM-L2's?
Re: XM18vn Project
Oh ok, so now we just add the lux of each emitter together? Im just going to duck tape 2 k40's together i have a 800k+ super thrower!
Well I suppose I could be wrong but I figured if you had two of the exact same light and shined them at the same object, the measured LUX on that object would double...is that wrong?
Re: XM18vn Project
I guess i am thinking that they are shining in the same "direction" but not on the same "spot" parallel lines vs (hate to use this word but all i can think of) "collimated" lines. Im sure with the reflector angle most of them will overlap though. I see your point, sorry if that sounded like a stab TT
Re: XM18vn Project
All 18 reflector will have an area of overlap in the beam. This point of overlap create a perfect round and focus hot spot with the intensity added. Of course the focus and intensity of the overlap is less ideal as the reflectors spread out more but it's still good. From the beamshots u can see the Xm18 throw close to a TN31vn already so getting it to 600K to 800K is not impossible.
Re: 24,000 Lumen Light Coming Soon ;-) LOL
That light is bad ***, I wish I had the cash to get one:shakehead
Re: XM18vn Project
You always said you wanted to work on the XM18.
Be careful of what you wish for!
Good Luck
Re: XM18vn Project
Just sucessfully dedome 18 LEDs. A MUCH HARDER task than I thought it would be. Now I am boosting the current. I wont knwo ho much current I am boosting as I cant measure the factory but it's getting a healthy boost for sure! 🙂
Re: XM18vn Project
Wow Vinh. Can't wait to see the new beam shots! Can you buy another one and then post side by side pics of the stock version next to your modded version in a large field? Thanks.
:nana: :crackup:
Re: XM18vn Project
LOL
This is the most stresseful project of all time. Centering 18 LEDs at once is no joke! LOL
:nana: :crackup:
Re: XM18vn Project
How abotu we all pitch in $100 to buy one. and then take turns Playign with it LOL. Sell it at the end to when we are done. All sign the back!!
Re: XM18vn Project
Haha, that sounds like a good idea. It would be fun to play with!!! But at only an hour of run time on high then 13 hours to charge it (can't switch out the batteries and can't turn it on while plugged in), I can't really see any real world use for it. The medium output is 3000 for 5 hours, but you have made much easier to carry lights that can put out those lumes, and you can pop in new batteries when needed.
Re: XM18vn Project
You dont reason with the XM18. And you especially don't reason with the XM18vn! The penalty is :poof:
