What did you do to get such good firefly modes on these Jon?
the firefly modes are stock to the drivers
stock Olight uses No PWM driver and low CRI Cool White LED, has a stock firefly mode of .5, by far my favorite (the LED was swapped to high CRI XPL)
stock Maratac uses PWM with Low CRI Cool White, (swapped to a No PWM Thrunite driver, whose stock firefly mode is .04. I find it too dim. The LED was swapped to high CRI XPG, (which is cooler than the XPL swapped into the Olight but still excellent CRI)
stock Thrunite uses No PWM and low CRI LED, but can be had in Neutral White. I find its stock firefly of .04 too dim to be practical majority of the time. otoh I really like the Thrunite body form factor (I like the thrunite form more than the Maratac which is a bit narrow in the body)
stock L08 uses No Pwm and Neutral white High CRI N219a, with .09 firefly. By far the most versatile modes, as it has 4 instead of 3. That is the ONLY stock High CRI light with a NO PWM driver that I know of. Though I find the .09 too dim, its second mode is 3 lumens which I find very useful. The only downside to this light is its a bit larger than the others. It is far and away the least expensive High CRI light in stock form.
my goals were to have No PWM and High CRI Neutral or Warm, I dont like Cool
The modified Olight is my favorite combination of features, High CRI, Warm, floody XPL, most useful firefly. The LED mod was done by Gunga, and I highly recommend his work. But not everyone wants a candle colored LED, which is what I really like about it. That is my warmest light with best firefly.
otoh, if max brightness is the goal, which means it will have Cool White and Low CRI, then I recommend Vinh's TiSvn. But that is in a whole other battery format, the high powered LiIon 10440. With DriverVn option, it can go down to 1 lumen and has 5 modes. This is by far the most expensive and brightest custom Thrunite option. It will have the shortest battery life, but uses rechargeables.
