Be-Seen Triker
- Joined
- Jul 15, 2011
- Messages
- 53
Ever wonder just how much runtime you have with your single 18650 XR-E Q5 flashlight? :huh:
I'm doing a series of experiments to see what my lights are really putting out. I am using the cheap 18650 Q5 zoomies for be-seen lighting on my recumbent trike. These have no boost or buck circuits and the video really does well in showing what happens if you draw 1A at the start of your charge.
The inside scoop is that I got 3 hours out of a quality 2350mah Panasonic cell. In strobe mode, I've gotten 6.5 hours (~50% duty cycle) in the same setup. The only reason for the extended runtime is that the Vf at the emitter keeps going lower from the beginning of the charge so the current is also dropping. There is no obvious regulation going on, only a Vdrop at the regulator and other circuit connections (~150mv total). In the same 1-amp test on an XP-G R5 I only got 2 hours but the output was much more consistent (video in process). I suspect an XM-L will do even better with a current regulator at 1 amp, but runtime will be less than 2 hours, I'm sure.
Just stop the video if you need to see the details. :ironic:
edit: XP-G R5 runtime test added - same format and extrapolated data at the end of the video.
Very nice result!
Edit again: XM-L T6 results added
At 1 amp drive from a single 18650, the XM-L and the XP-G are virtually identical. The XM-L should put out about 8% more light; the drop off at the end of the charge was 15 minutes for the XP-G and 10 minutes for the XM-L. Nothing to write mother about.
Very nice result!
