Re: Zebralight H501 specs
Sorry, but I have to disagree about loosening the cap. That's a band-aid approach to the problem. That's defeating the whole purpose of having a clickie switch so you can operate with just one hand. twisting the cap is two-hand operation. You might be better off with the H50 if you have to twist to the cap in on the H501 before you use it. The other problem with loosening the cap is exposure to water and moisture. Might as well throw out the O-ring. What's use is it if the cap is loosened?
yes, your indoor experience is the same as mine. it's an excellent headlamp for the indoors with the output well spaced out for different tasks.
i do wish for more power, hey who doesn't, but i think they are already pushing it with the limitations of heatsink size. it gets pretty warm on high and when used as a headlight there is no hand to remove heat.
the only solution is some sort of aspheric lens accessory.
i could make a hack job one. the 20mm aspheric one i had before shown. glue some thick o-ring in the back. glue some elastic band at the lens edges to hold it on the head. but i rather zebralight come up with a clean accessory 🙂 besides i bought this for flood for hiking to be combined with a thrower. 2 light doing what they are designed for. i'm not even sure i would use an aspheric accessory. i feel like it's like putting sport wheels on a suv trying to make it something it isn't.
i'm beginning to understand the switch though. if i wanted to operate it on my head, i want something easy to press. if it was harder to press then i would need my finger on the other end otherwise i would shift the headlamp on my head from the effort.
i'm fine personally with locking out the tailcap. i do it on my other lights so it's 2nd nature and i think a good habit in general.
i agree with the h50 h501 statement. if someone were to use it strictly indoors the h50 would better suit with the wider angle. someone using it indoors and out would benefit from the h501.
