For several times my H502 couldn't be turned-off. It skipped modes when I tried to turn it off. Removing the battery was the only way to turn it off. If this happens one more time, I will send it back.
Did I say I hate that glowing thing? I now believe it produces the green edges.
I like the 120 degree beam very much.
I haven't had any hint of the trouble turning it off. Sounds weird. Contact problem? Yeah, by all means send it back if it continues.
Those who think that the GITD may be affecting the beam tint--does that add up in terms of the magnitude of lumens that are at stake? You are suggesting that when the LED is blasting out 200 lumens of white light, the GITD is producing enough lumens to make a ring of light around the edge that your brightness-dazzled eyes can notice. But if that's right, then when the LED is off and your eyes are dark-adjusted, you should be able to turn the GITD face to a white wall and see a large patch of green on it from the GITD.
Whereas, even with dark-adjusted eyes, I can't get the GITD to make any kind of noticeable light-patch on a white wall a meter or more away. It just doesn't send out enough light for that--it is putting out far less than the lowest low, which is 0.01 lumens--so the GITD is putting out far less than 0.00005 of the total output. Since it does not make a huge green ring or circle on my wall with the emitter off, how can it be making a huge green ring around the edge with the emitter on?
Is the idea that the emitter is somehow exciting the GITD enough to make it contribute more lumens? Or that a tiny amount of lumens, less than 0.01, are polluting the other 200?
I'm just not seeing the scenario. And haven't other people referred to a more general phenomenon of an "XM-L green ring" that shows up with other lights that don't have GITD features?
I have to say, I don't have much use for the GITD face myself, and if they offered models without it I would not pay any extra to get it. But I don't mind having it, and I certainly don't see how it can be affecting the output of the emitter when the emitter is on.
The H502 has, in my view, all and only the weaknesses I knew about before buying it: it is a cool emitter (I will much prefer the neutral, I know) and it is a pure flood, no-throw beam.
But it also has all of the strengths I hoped for: tiny, compact, bright, and wonderfully even light. 123 performance from a AA format. You never feel like you are wearing a light. But magically, everywhere you look is bathed in a gentle glow of light. You feel like you are inside of a bubble of light, like you are Glinda the Good Witch or something.
It's not for all uses, and it is certainly not for everyone. But it's an incredibly neat light to have for some purposes.
