Hmmm, I put my H50 in the glass of water and took it out after c.a. 30 minutes.
It it wasn't "static", then can you explain what means "static" for you?
IP norm describes both waterproofness and dustproofness.
Meeting IP68 standard mean that item is completely dust and waterproof.
Fist number (here: "6") describes dustproofness, second (here: "8") waterproofness.
Below you have description of all levels:
Dustproffness:
0 - not protected (sometimes: "x")
1 - Protected against solid objects greater than 50 mm³
2 - Protected against solid objects greater than 12.5mm³
3 - Protected against solid objects greater than 2.5mm³
4 - Protected against solid objects greater than 1mm³
5 - Protected against dust - limited ingress (no harmful deposits)
6 - Totally protected against dust
Waterproofness:
0 - Non-protected
1 - Protected against vertically falling drops
2 - Protected against direct sprays of water up to 15 degrees from vertical
3 - Protected against direct sprays of water up to 60 degrees from vertical
4 - Protected against water sprayed from all directions, limited ingress permitted
5 - Protected against low-pressure jets of water from all directions, limited ingress permitted
6 - Protect against strong jets of water from all directions, limited ingress permitted
7 - Protected against the effect of "temporary" immersion between 15cm and 1m
8 - Protected against long periods of immersion under pressure [usually 1m for 30 minutes]
9K - protected against high pressure, high temperature jets of water from multiple directions (according to DIN 40050-9)
As you see, IP68 norm mean that item should be completely dustproof and waterproof for certain time and under certain pressure.
The pressure in a glass of water (10cm under water) is far, far below that which you have 1m under water.
I know that you like your Zebra.
But please, don't tell "fairy tales" that it meets IP 68 standard when it is too many reports that it is not.
You can do your own tests, but don't blame me if it will stop working.
Just for fun - how waterproof things are tested by users:
IP68 Otterbox:
And some IPx8 GPS unit:
Should I mention that none leaks were reported for tested items?
And nice IP68 test video (according to your "mobility" doubts):
http://pocketcctv.com/IP68Video.html
At last, to be clear: I am not saying, that lack of waterproofness is something wrong. I just like to know that, then I can take proper care about it.
My "accusation" to Zebralight is that they are declaring certain level of waterproofness, which they don't meet.
If I didn't make test by myself (and before that, read about some issues) I would put this light to the river or lake being sure that it will survive that - like all my other IPx8/IP68 proof items do.
[UPDATE:]
I never meet "IP68M" norm, so I did a little research.
It seems that there is no IP 68M standard, or it is not described as a regular norm. Or is really new and there is no definition of that standard over all internet (or is not in english :"P).
Can you post some link to the definition of that norm?
Here are links to abstract from IP standards definitions, including the "9K" extension:
http://www.stegmann.com/comm/Protection.pdf
http://www.kenplas.com/topic/ipcode.aspx
No word about "8M" standard...
Maybe it is some kind of "sub-norm" given by some producers by themselves? According to info from CPF, "M" should mean "it will keep that condition even actuating on its moving parts. i.e. switching it on-off". In cases which I've found (or during my own tests), lights were turned on, and submerged afterwards - no operation with a switch or cap (there are no other "moving parts") was done underwater.
According to above definition of this mysterious "M" standard, all issues should be described as "static".
