noboneshotdog
- Joined
- May 28, 2012
- Messages
- 1,352
Well Gentlemen, looks like the neutral is out for pre order. The waiting is almost over!
Hi cpfers!
just wanted to share a detail about the sc52 you'll probably come across if you own one
I noticed the turbo mode on the sc52 (500 lumen, 1 min) is quite demanding on the li-ion cell, easily 2c if not more. If you have cells like mine, which are tired even when fully recharged, you will have a voltage drop below 3.1v during the turbo (or if your cell is partially discharged too). So you will experiment a shorter turbo, with step down to medium instead of the usual 280 lumen H1. Didn't quite understand it first, but with the voltmeter now I do, kinda make sense. Guess it's time to buy new 14500's.
cheers.. : )
Great review! Love my SC51 (don't understand why more people don't own Zebralights) and will seriously consider upgrading to the SC52 as soon as they put the XM-L2 in it.
Typically yes, but that's highly variable. For example, when the XM-L2s first came out, T6 neutral whites were common (along with T6 and U2 cool whites). I've seen reports of neutral white U2 bins more recently ... so it is possible that common specs could be accurate for both. I have no specific knowledge in this case, however.As most of you may know, the XM-L2 is available. Just ordered one, not sure why the specs for the Neutral White LED are the same as for the cool one, usually the warmer LED's are slightly less lumens spec wise?
Yes, I am planning to review the SC600-II, with the new XM-L2 (standard cool white version though). A couple of other reviews to get finished first, though.Definitely will be trying out more of their products, looking forward to see what you think of the SC600w Mk II.
Not sure how many response you are going to get (other than the general recommendation not use alkalines).After reading things and crunching the numbers, I realize that the sc52's performance on alkalines is quite crummy, especially in H1 and H2A. A severe drop in brightness after 10 minutes is not very usable, though it's understandable due to the very high current drawn from that single AA. (This issue is less severe on my Quark AA-2 XP-G R5 where currents are lower)
Adam please do not change the thread title - Norm
It's been a long time since this review, and I haven't heard of any issues since the original launch. You should be go on that front ... don't know about XM-L2 update, but I presume one would be coming at some point. You would need to check with ZL.Thanks Bro for another Awesome Review ....So ... is the Flicker Issue on 14500 fixed yet ? also, XM-L2 Cool White version anytime soon ?
