Zebralight SC62 and SC62w
Candle Power Flashlight Forum
Help Support CPF:
Here is a link to a post in which I conduct some temperature vs. output over time graphs: http://www.candlepowerforums.com/vb...-Impressions&p=4492700&viewfull=1#post4492700
The long and short of it is that sitting on a table running on high, it continually reduced output over the course of 5 minutes at which point it held steady at ~60% of max output. I ran the test again holding the light tightly in my hands and was able to sustain 90% output at 5 minutes.
Great, thanks! I read many times people talking here about heat dissipation throught the hand, but didn't know how effective it actually is. Now I can sleep soundly :thumbsup:
Hi,
I wasn't sure if I should make a seperate topic for this or wether there is a more suitable thread on here as it pertains to the difference between two Zebralight models?
I am really having huge difficulty deciding between a Zebralight SC62W and ZebraLight SC600W MKII L2. Both seem like really great lights with a nice warm / neutral tint.
I've been reading various topics on here but still not sure which to get. Both are similar lights, similar price, except me being from the UK, I can only purchase sc600w right now and will have to wait until SC62W becomes available over here. Wish I knew when that would be.
From what I understand, the 62w is smaller and lighter but the size is not an essential requirement for me and I could live with the size of 600W. Most important things I am trying to determine between the two models are:
Battery life / drain between the two until you can no longer use H1
How long the light stays on maximum H1 before it reduces noticably to say 50% of maximum, as I would be using the brightest output mostly, but in bursts of maybe 20 to 30 seconds or less before turning off for maybe a minute or more. Which performs better in this scenario or are both equal?
The brightest torch in real terms
Difference in spotlight between the two - floody vs focused spotlit, warm tint.
Overall quality, build and switch.
PID stepdown between both as i'm not sure if 600w is temp regulated and smoothly steps down like 62w.
Overall opinion on which is better / I should get.
Best battery recommendations / ones to avoid
I would really appreciate any help guys and hopefully I can make a purchase decision soon :-)
Cheers
If you don't care about the larger dimensions it seems to me that the SC600 will give you more output and a floodier beam, both of which sound like positives for you.
I'm probably going to get rid of my SC600 and go with an SC62w eventually, primarily because I like its form factor better and the high on it is still more than adequate, and quite impressive too.
@JamesW. This is not a tough decision. Get the SC62w.:thumbsup:
I second to this. I have both lights but I love my SC62w because of its size. Output wise, its the same for me and both are running on 18650 li-ion, so runtimes will be the same depending on the capacity of your battery.
@ JamesW. I've learned the best answer here in a case like yours is to get both ��
Just got the CW version! It is a nice light. :) UI really is really kind of simple. When I first read it, it appeared complicated!!
I like all the mode options and the PID is a great idea,,,,,,,,the light really never got too hot,even tail standing for 15 minutes on High[around 65F inside]. When I use it outside tonight the cooler air will most certainly help. I am bringing it w/ my modified search lights for my nightly hike. I think I will always bring it, a 3rd light, back up and emergency light that will still get some use outside of my house!
One advantage of having a decent amount of lights is when one does NOT come w/ a holster[this light!] I always have one that fits. This fits perfectly in my SWM C20C holster.:thumbsup:
ps to zanders: I also have the V11R. The SC 62 is no doubt a better EDC light all the way around,run time [battery config.], modes, output ect.!
Would someone be able to give me a quick rundown of the differences between the SC62w and the SC62? I understand that The "w" model is supposed to be neutral white (which I hear runs warm). This will be my first real light, as I currently carry a Streamlight Stylus pro. I keep hearing about the 62w, but not much about the 62. Is the 62w objectively better? Thanks for the help!
I do not know all the technical aspects of lights. I do know that "Tint" is all a matter of preference! The 62 is Cool White. that is what I have. I also have several lights on the warmer[tint] side. They are modded and that is a result of dedoming. I like them also!!
I am not sure if I helped you too much!! what "Tint" is your stylus? Do you like it? If so, maybe you should get that tint?
Good luck,,,either way it is a nice light!........Cool white will give you about 70 more lumens!!! :)
P.S ,,,,,,WELCOME TO CPF!!! :party:
Welcome to CPF! You will find this place a very conducive environment to be in. Most of our members here are very nice folks who are both helpful and polite. But be warned, this place will also help you empty your wallet much faster than you can anticipate if you are not careful. Lol!
Back to your question. It is hard to tell you what is best for you without understanding your preference. As what capolini had mentioned, tint is a matter of preference. Some like myself prefers neutral white (slightly warmish) and warm tint (pretty warm and incandescent like), and some swear by cool white. The general guideline here is that if you are using your lights mainly in the great outdoors or a walk in the park, you will find the neutral white tint more pleasing to the eyes as it helps to separate the browns from the greens better than a cool white light. If you are using the light in an urban environment, cool white works perfectly fine.
Lets talk about brightness. On paper the cool white SC62 appears to have 70 more lumens than the neutral white SC62w. In actual use, you most likely won't notice the difference in brightness because our eyes see things logarithmically. It will take at least a 40% increase in brightness before we can perceive any change at all in brightness. However, we will most likely feel that the cool white is brighter even if the lumen ratings are the same because our eyes are more sensitive towards the whiter spectrum than it is to warmer tints.
If you need a light to blind someone for defense, or you need a light that appears technologically more advanced looking than a good old incandescent bulb, or perhaps for use within the house and office where light tint doesn't really matter, the cool white SC62 won't disappoint. If you need one for use in the outdoors, or you reside in a place that has tons of greens outside, you might want to consider an SC62w.
Following the CPF saying, if unsure, buy both. I did warn you that this place can be pretty influential in helping you empty your wallet, didn't I? :)
I see H1 Is 1000 L, M1 is 70L. That is a big drop off. I see that H2 is 620L/350L/160L. Anyway to make H2 turn into M1??!!!LOL!
No way to turn H2 into M1. But H2 set to 350L makes a nice spacing, IMO. 1000L>160L is a bit much for me. So you'll have:
H1: 1000L (double click to)...
H2: 350L
M1: 70L (double click to)...
M2: 32L
etc.
