Here is a hot new part for you guys.
Do you run a:
- Direct Drive Triple XPG
- SST50 pocket rocket
- SST90 pocket rocket
- Incan hotwire
- Anything with high current needs
Todays high current lights are in need of a tail cap that can handle the load.
There are no tail assemblies with any spring, or switch that can deliver the full power to your drop-in at when dealing with a 5-10 amp load.
Until now.
This is a simple twisty mod to get the power out the front of your light.
We have tested many of the available options.
These can provide HUNDREDS OF EXTRA LUMENS OUT THE FRONT compared to anything else out there with a spring or switch when dealing with the 5-10 amp loads that we are now seeing daily around here.
Installation:
-Simply pull the spring from your aluminum cup.
-Pull the aluminum cup
-Drop in the brass ZERO RESISTANCE mod
-Tap pin into place tightly
- Enjoy your light brighter than ever before.
A few words of caution:
Test battery fitment carefully the first time that you use this tail mod. Screw cap on slowly to be sure that you do not crush your cells.
This mod should work perfectly on any single cell bored surefire, and many other lights.
This mod will truly deliver all of the current to your drop-in that is available.
Use care when lighting up your direct drive setups the first time.
THESE DELIVER OVER 200 EXTRA LUMENS OUT THE FRONT on my Direct Drive Triple XPG drop-ins compared to a McClicky.
FOR SALE NOW
http://www.oveready.com/surefire-upgrades/oveready-zero-resistance-z41-upgrade/prod_150.html :thumbsup:
FOR SALE NOW
These will ship after 6/17
Do you run a:
- Incan hotwire
Until now.
Installation:
FOR SALE NOW
FOR SALE NOW
