Zhaga < the LED Consortium
orbital
WI
This newly formed consortium for LED lighting uses wording such as 'light engines' ~ 'upgradable' ~ 'heasinking'~ even 'LEGO'
to describe the future of LED modules for worldwide standardization & application.
~ we at CPF have been using these terms for yearslovecpf
http://www.zhagastandard.org/ <<< Cree is one of 193 companies on board...
.....ETA on P60 light-bulbs?
:devil:
I noticed this when reading a Cree document linked in another thread.
While the concept has promise, it also struck me that it could also be an exercise in the old joke about standards : Standards are great - there are so many to choose from.
FAQ from Zhaga site:
Definition of LED light engine
Zhaga uses the term ‘LED light engine’ to describe the combination of one electronic control gear and one or more LED modules as defined in Zhaga industry specifications.
Definition of LED module
An LED module is a unit supplied as a light source. In addition to one or more LEDs it may contain further components, e.g. optical, mechanical, electrical, and electronic components, but excluding the control gear.
Definition of electronic control gear or so called driver
An electronic control gear or driver is a unit that is located between the power supply and one or more LED modules to provide the LED module(s) with an appropriate voltage or current. It may consist of one or more separate components, and may include additional functionalities, such as means for dimming, power factor correction, and radio interference suppression.
Who is Zhaga?
Zhaga is a global consortium of companies from the lighting industry and beyond, founded in February 2010.
What does the word Zhaga stand for?
The word Zhaga has no intended meaning. It is a waterfall in Sichuan. The Zhaga logo stands for interchangeable LED light sources.
Who initiated the Zhaga consortium?
Zhaga started with broad support from the lighting industry. Already twenty-two companies participated in the first meeting of the Zhaga consortium in March 2010.
How does Zhaga ensure the interchangeability of LED light sources?
Zhaga develops specifications that, when applied, ensure interchangeability. Therefore Zhaga focuses on the mechanical and thermal fit of the heat sink, the size and height of the light emitting surface as well as its photometric properties regarding different application areas.
Zhaga does not specify the performance, quality, design or safety aspects of LED light sources as these characteristics are for each LED light source manufacturer to decide for themselves, based on the particular technology chosen and market approach. They are not specifically related to interchangeability.
Does Zhaga also specify the connection between LED modules and electronic control gear/driver?
No, Zhaga does not and will not specify the interface between electronic control gear and LED modules. This interface is rapidly evolving and not stable.
Will manufacturers have to use the Zhaga specifications in the future?
No, the use of Zhaga specifications is voluntary and not mandated by any government or regulator.
*****Some of the wording I purposely increased in size,,,specifically look at the use of the word driver,
...you don't think these guys frequent CPF 😉
So, these Zhaga consortium folks are lurking around CPF, you say? I say lets feed them a steady stream of misinformation while we form our own standards and name it after a random rock formation in New Guinea!
Well, I guess a modular heat sink would be nice. I'd like to see panel-shaped units with shared ducting to lego together. Filter & vibration-isolated fan on one end, grate on the other to keep fingers and squirrels out. A temperature sensor can adjust the fan or LED. Heck, any driver can measure its LEDs temperature by Vf, so that's more control. Add an ambient-noise sensor and you could create several profiles, from 'maximum light' to 'minimal added noise.'
Seems like the terminology is fairly standard - 'driver' is a pretty generic term for circuitry that provides some amount of power.
Even back around the time I started playing with electronics, there were 7-segment LED display drivers and LM391x bargraph drivers.
"Driver" is pretty standard.
"Light Engine" is somewhat standard, however most things called "light engines" on CPF also include a heat spreader for thermal interfacing.
"LED Module" is quite hazy with immense wiggle room - essentially a LED (or LED's) with some other component(s). I foresee this being a popular type classification with each manufacturer promulgating their own standards - likely for their own benefit in order to build a product line from common building blocks rather than to help users with modularity or replacement.
Maybe Zhaga is trying to be the new Phoebus Cartel. That's actually a pretty quick but interesting read on wikipedia.
