D
**DONOTDELETE**
Guest
Sorry to hear about your ZLT+ problem!
The component with the three legs is the transistor.
What power source were you using? MrAl reported similar problems with a 1.5-volt source dropping below one volt.
The transistor may also fry if, for some reason, the 300 does not turn it off as it should. This may happen if the resistance between the transistor emitter and the 300's Isense pin becomes nonzero for some reason, on the order of even a few milliohms.
One possible cause is cold or oxidized solder joints. I guess the best advice is to make sure all the connections are as clean and solid as possible, especially when resoldering.
Or when adjusting Rsense, maybe the lead that goes to ground should be resoldered instead of the lead that goes to the 300 and the transistor. That way, the critical connection only needs to be soldered once, and there's less chance of oxidation.
Another possibility is solder splatter. Once, when I was testing various inductors, a small blob of solder landed between the + pad and the trace that goes to the transistor base. When power was applied, the transistor was quickly toasted. With circuits this small, even a tiny solder blob can wreak havoc.
