Hi,
My LED is 3W 700mA max
AVAGO TECHNOLOGIES|ASMT-JW32-NVV01|LED, 3W, COOL-WHITE, MINIMUM 100LM | Farnell LT
Power source is 1.5V batteries x3 = 4.5Volts.
I would like to use ZXSC300 because it works up to 0.8V and I don't want to waste any power from my batteries
Here is datasheet for ZXCS300:
http://www.diodes.com/datasheets/ZXSC300.pdf
I tried to use ZXSC300 Feed Forward calculator here:
http://www.diodes.com/_files/calculators/ZXSC300_Calculator.xls
But I'm not sure my input power is 4.5V and calculator allow to use lower voltage than LED forward voltage 3.8V in my case.
Furthermore calculator allows to use 500mA and my LED is 700mA
I also have this datasheet that shows a setup to power 500mA led
http://www.diodes.com/zetex/_pdfs/3.0/appnotes/apps/an65.pdf
But it's for 3V input, if I have 4.5V and use 40mR sense resistor I think it should peak at 700mA. Thats just a guess.
