Re: Fraz Labs Mechanical Flashlights (formerly QTC Non-Battery Crush)
Is there a particular 18650 that you recommend for the tiny nugget?
Quote:
Originally Posted by
jabe1
As long as it's not longer than 2.57" or so, you should be okay with any of them. We recommend unprotected cells based on the shorter length, but we've made adjustments to the last batch of lights that should be more accommodating to protected cells.
Remember folks: So long as specs and power calcs look good, you can go with nearly anything on the market in terms of emitter choice. I recently powered an SST-10-UV 385nm using 2x18350 in a Lumenite 21700 host as a proof of concept. And have a pair of KW CULPM1.TG incoming from the Convoy storefront off Aliexpress to test. CULPM1.TG DD powered by 1x21700 (Moli P42A) through a 35mm optic? Should be very, very interesting...
Do you plan to run the Osram pair together..
What optic pairs duo emitters?
As a single emitter through a single optic. I purchased a pair to be able to confirm batch consistency. And just in case their lot of KW CULPM1.TG sells out, being advertised by Convoy as the third highest flux bin (8RF) available. As a point of reference, Mouser has 7RF available which is specified as 200 lm fewer at 6A.
Outstanding shot. Ad-worthy right there :thumbsup:
Which LED is that? There is a distinct tint shift in the spill.
adamlau
Definitely
jabe1
Sst20 ? Looks like. Just a guess
Is there an estimate on when the lights that were offered for sale last week will ship?
adamlau
This is correct in that most modern emitters on 16mm MCPCBs will work. I generally don't recommend multiple cells however (as cell charge imbalance can cause catastrophic failure with lack of protection circuitry - also high Voltage mismatch can fry the LED even at extremely low amperage). We're just now getting into looking at some single-cell higher voltage options...
Bravo30
Love this pic.
wolfstyle
All are shipping tomorrow. We're getting around to PMing CPF members with requests tonight, and there will likely be a few more on the website late tonight.
Also, there are a couple lights I'll probably offer in this thread here in a bit (have a flood-based not-quite-a-mule optic option that we haven't done before).
So I know my projected delivery date and yet I find myself refreshing the tracking page 😆
Fraz or speckacuda, on your updated website I see some hard dimensions for maximum recommend battery length. We just need a max dimension for 18500 please 👍 Watching the tracking like a hawk 🙂
Fraz, looking for that emitter swap video please 👍
I’d like to get one. Either the 23650 or the 18650. Boulder, Colorado
My Tiny Tank 18500 arrived today. It lives up to it's name, it's a tank. Just a solid chunk of aluminum nicely machined. It makes my other lights seem flimsy. The milled flutes make for good grip. Very, very nice.
@discoverEDC You know the deal: Pics or it didn't happen ;) . You have a PM :) ...
adamlau
LOL, it's been a LONG time since I posted any pictures to the forum. I'm not sure I would even know how. PM sent.
discoverEDC
Sorry, I promise I'll get on it - I get so distracted at the shop.
ipaulr
Got you down.
discoverEDC
Hope you like it! How do you like the LED? It is definitely warm (seemingly a bit less bright than the cooler ones). You also got a slightly frosted optic to spread the beam evenly.
Been using my 18350 tiny tank almost every day now. She’s a solid little light that’s for sure.
TheFraz
Sorry, I promise I'll get on it - I get so distracted at the shop. Got you down.Hope you like it! How do you like the LED? It is definitely warm (seemingly a bit less bright than the cooler ones). You also got a slightly frosted optic to spread the beam evenly.
The warm emitters pay an output penalty because of how thick the phosphore has to be to get the very warm color temperature. 3500k was the warmest that you had on hand but I ordered several 3000k MCPCB's and will be trying them out; one of those will likely stay in the light. Unfortunately I couldn't find any Samsung's in that color temperature (yet). The light frost optic made a nice beam pattern with the 3500k SST20. I'm also going to try a clear spot optic with a bit of DC Fix diffuser film in the center. I tried that with one of my 26mm optic lights and it knocked down the square artifact and still left a some throw.
Just got my 18500 Tiny Nugget. This is about as bomb proof of a light as you can get. I love it. The box is awesome too! What a super deal!
I would love to see an emitter swap video also. I have been carrying my 18650 tiny nugget every day as my main light. Such a great well built light. I definitely want to pick up more. I also would love to have an 18350 battery tube.
Mgizler
Extra tubes would be great. I want a 21700...
Another great thing about this light is the mass keeps it from getting to hot to hold on max output.
The only negative I have found is for me it takes two hands to turn it on/off.
BTW the run time in loooong
Glad you guys are enjoying! At the shop making more as I type this....as seen below a pic of the lathe making part of the piston assembly (one of my least favorite things to make). Thought about taking a sneak pic of Speck on the mill, but she'd probably kill me.
Also working on making them a bit easier to turn while still being very waterproof.
I'll work on that vid (LED change-out) too. As soon as I get the machines on a long op, I can put some of it together.
https://i.imgur.com/LXImmSl.jpg?1
Very nice! Keep on turning.
