This is a technical question for experts on bulbs and why some bulbs of the SAME wattage are said to have higher lumen output.
My problem is not about flashlights but my crummy Ford Explorer's headlamp system.
In studying lamps and their luminous output vs. wattage, I am finding specs that don't relate clearly to wattage. It seems that some bulbs of the same wattage have more luminous intensity. The Sylvania SilverStar bulbs, for instance are maybe 8% brighter than OEM bulbs of the same 55-watt rating.
Some 130-watt bulbs I tried were no brighter than the SilverStars.
Now I know my testing was flawed because the stock wiring in the Ford is absurdly under-capacity. There was almost 3 volts dropped in the wiring to the bulbs, referenced to the battery voltage. The higher wattage bulbs got less power for this reason.
But even all things being equal, some bulbs are brighter.
I can think of only two things:
the brighter bulb of a given wattage has a clearer quartz bulb that lets a higher percentage of light pass through.
The brighter bulb probably runs the filament at a higher temperature (shorter filament or fewer turns of tungsten wire?)
There may be other reasons. But I was interested in hearing from our bulb experts on the physics behind luminous intensity and why two 55-watt bulbs are not equal intensity. Is it the reasons I cited, or is there more to it?
