Hello Blr,
Welcome to CPF.
I believe you may be misunderstanding the Sanyo information.
The - delta V termination is utilized by most of the high end chargers because it gets more capacity into the cells under a wider variety of ambient temperature conditions. Temperature is used as a back up in the event the - delta V signal is missed, as you have indicated.
The ICE and Triton chargers can terminate on maximum temperature, but I am not aware of any charger that is utilizing dT/dt for termination.
Sanyo indicates that they are rating their cells by first charging them utilizing a -deltaV=10mV for their charge termination.
Here is the discharge information on their HR-3U 2500 mAh cells. Since I expect a battery manufacturer to list their cells performance under the best possible conditions, I would conclude that using a - delta V = 10 mV termination is not detrimental to the normal cycle life of the cell.
I believe the confusion comes from
this document. In chapter 3 I believe they are saying that while you can use a NiCd charger to charge the Sanyo cells, it will reduce the cycle life by 20%. (NiCd chargers typically utilize a 20-30 mV delta V value.) To keep from damaging the battery, you should utilize a - delta V of 10 mV or less.
It is also interesting to note that Sanyo suggests that in order to get a proper end of charge termination you need to charge at a rate between 0.5C and 1C.
This means that when you compare charging at 700 mA vs charging at 2000 mA, charging at a lower rate should end up with hotter cells and may possibly do damage to them in terms of cycle life.
I would also like to know where you got the idea that the Lenmar Pro66 uses temperature as a end of charge signal... I was unable to find a spec sheet on that charger, so I called them. They told me they use -delta V termination on that charger...
Tom
