Does the Pila GL-2 normally come with a spare bulb? I ordered a GL-2 and a spare bulb, and the good news is, I received it with a spare bulb ( ) but it was included in the box with the flashlight, in a little cutout in the foam where a spare bulb was clearly supposed to be... so I wonder. Do they normally come with a spare, and I didn't get the spare for which I paid an extra $20ish? Or do they normally come without a spare?
For what it's worth, a couple thoughts on the light itself:
Good things: It's just a really cool design. LEDs for low light and xenon for brightness, pushbutton works fine and can be locked on or locked off with twist.
Other things: Slightly oval-shaped beam. Peak brightness seems about equivalent to my Streamlight TL-2, but with a bit more spill/flood. The LEDs have a slight blue tint. The LEDs are almost impossible to keep on using the tailcap button as it only takes slightly more pressure to activate the main bulb, but screwing the tailcap in to the right spot for the LEDs is trivially easy. No clip. Short, but a bit more bulky than my TL-2. Unscrewing the tailcap for lockout makes the tailcap almost spin freely. There's some friction, but not much. (Still takes about 3 turns to actually remove it though.) I folded about 2 inches of teflon tape into a tiny square, applied it to the threads, and now it feels secure when it's locked out.
Conclusion: nice light for EDC if you have a roomy pocket. The bulb is bright enough to light your way, the LEDs are comfortable for reading a map.
But how many bulbs do they normally come with? Just the one in the light, or is there normally a spare?
